does not rev abov 3k?
Old May 15, 2006 | 10:21 AM
cool_as_crap's Avatar
Default does not rev abov 3k?
I was test driving my friend's ef sedan i will be buying from him, but as soon as you hit 3k rpms, the tach jumps all over the place and the car bogs down. Im thinking it's the distributor, but i just wanted some other opinions.
thanks
Old May 15, 2006 | 01:50 PM
jamclaur's Avatar
My friend is having the same problem with his GSR.. We are looking for a new ecu, tell him to try that.
Old May 15, 2006 | 01:52 PM
heyitzspikey's Avatar
im 95 % it is the ecu makeing your car run like that cus my motor was acting up like that so i switched the ecu out and it ran better.
Old May 15, 2006 | 02:34 PM
JDM tuning702's Avatar
it could also be losing compression..that happened to my friends EK at 5K..ended up blowin the motor that same day..
Old May 15, 2006 | 05:45 PM
i dont think it is compression, it runs strong up until 3k when the needle just starts to jump around and the car just bogs
Old May 15, 2006 | 06:52 PM
bobbyg crxh22's Avatar
Default Re: (cool_as_crap)
i have the same problem....yes it is the dizzy...some guy read the ecu for me and it said dizzy and timing was fucked up in those exact words.
Old May 16, 2006 | 08:53 AM
ah great thanks. il check out some junkyards this weekend.
Old May 16, 2006 | 08:56 AM
crx_88_si's Avatar
is the check engine light on??
pull the codes from the ecu (lift carpet on pass side, turn key to ON (dont start) and count the flashes.
you will get 1 initial "on" flash, then count the flashes after that, then it will pause and start over.
3k rev limit = limp mode, could be a number of things, most likely the TDC sensor in the dist.
Old May 16, 2006 | 09:06 AM
CRXBart's Avatar
Default Re: does not rev abov 3k? (cool_as_crap)
check the rotor button. Sometimes the screw falls out causing the timming to be wacked out.
Old May 16, 2006 | 09:28 AM
yes the check engine light is always on, forgot to mention that.
what do the flashes mean? is there a distributor-specific code i should look for?
Afshin9393
13
Mar 4, 2011 12:40 AM
bub113
Dec 22, 2008 04:26 PM
90crxdxb16
12
Nov 27, 2006 03:09 PM
drew2
Dec 3, 2005 11:51 AM
Bizarre
Apr 16, 2003 04:59 PM
