ej1 rear sway?
Might be a dumb question, but i have searched, and nothing clearly came up that the 22mm type r rsb will fit on my 95 ex coupe? Im sure its a quick n easy answer, help is appreciated.
Yes, the ITR rear sway will fit. I have it on my EH2. I recommend getting the ASR subframe brace with it. Then you will have to buy the sway bar, brackets, bushings, endlinks, bolts, and rear LCAs.
Parts list for me:
- ASR brace = $185
- Omnipower LCAs = $100
- Sway bar with hardware = $170
All prices included shipping to me in Hawaii.
Parts list for me:
- ASR brace = $185
Ill be running an ITR swaybar on my EJ1 also. However, Im not using an ASR subframe brace. Ive heard plenty of people say its needed, but the EKs are the ones you have to worry about. My setup will be:
Function7 LCAs = $230
Beaks Reinforcement Package = $220
You could go with the Omni LCAs and Beaks kit and save over $100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93allmotorcoupe »</TD></TR><TR><TD CLASS="quote">Ill be running an ITR swaybar on my EJ1 also. However, Im not using an ASR subframe brace. Ive heard plenty of people say its needed, but the EKs are the ones you have to worry about. My setup will be:
You could go with the Omni LCAs and Beaks kit and save over $100 </TD></TR></TABLE>
Beaks is not a wise reinforcement for the ek because of the way its positioned. Search around and you will see the asr is much better. I hope you haven't purchased yet..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">
Beaks is not a wise reinforcement for the ek because of the way its positioned. Search around and you will see the asr is much better. I hope you haven't purchased yet..</TD></TR></TABLE>
I dont own an EK. I own an EJ1, the same exact thing as the OP.
Reading > you.
And I know the ASR brace is recommended for EGs as well. However, the EG/DC subframe is much stronger than the EK, and many EG users on this very site are using a 22mm sway bar with only a Beaks/BSQ kit as reinforcement and have had no problems for several years. Ill take my chances with my car, worry about your own
Reading > you.
B20EF
Jul 9, 2008 04:44 AM
opeth13
Jun 2, 2004 05:46 AM
