ITR Rear Sway on Civic EX
will an integra type r rear swaybar fit on a 4dr civic ex?
would i need integra bushings to make it fit...any comments would be appreciated
Re: ITR Rear Sway on Civic EX (X DaNish X)
What year Civic?
You will need the integra mounts and a beaks or BSQ kit to prevent your subframe from tearing.
Re: ITR Rear Sway on Civic EX (POS Hatchback)
yea they did, but i want to upgrade
plus its not connected right now b/c my friend fucked up the LCA where the bolt connects to the sway bar and the piece that holds the sway bar to the LCA, i think its a bushing is shot
Re: ITR Rear Sway on Civic EX (TURSpoonEK)
the LCAs aren't messed up, its just the hole that connects the LCA to the swaybar is messed up, he stripped the bolt and now he has to tap the hole to get the bolt through it. Plus the left piece that connects the swaybar to the LCA is shot. I thought they were called bushings, but maybe i'm wrong. I didn't wanna spend that much money on a swaybar, just something that is better than stock
It sounds like he needs new LCA's too since his boy fu$#ed em up.
I've got a 96 spec JDM ITR sway laying in my garage w/ bushings and clamps. I would definately recommend the beaks kit if you do go with any larger than stock rear swaybar.
does anyone know for sure if the balljoint mounting hole is in the same location on the EG rear LCA and ITR rear LCA?
http://www.beaksproducts.com/eg-quickswap.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X DaNish X »</TD></TR><TR><TD CLASS="quote">how much is the beaks kit and what exactly is it?</TD></TR></TABLE>
so that kit comes with the itr rear swaybar and everything i need to install it on my car?
do i need new LCAs?
do i need new LCAs?
OG triple OG
if your lca's are fucked then yes you do , and since you have a 5th gen id recomend getting itr lca's too
the beaks kit for me including everything was 180 , that was shipped with endlinks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK »</TD></TR><TR><TD CLASS="quote">if your lca's are fucked then yes you do , and since you have a 5th gen id recomend getting itr lca's too
If he goes with ITR LCA's won't he have to go with ITR struts in the rear also?
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback »</TD></TR><TR><TD CLASS="quote">
If he goes with ITR LCA's won't he have to go with ITR struts in the rear also?</TD></TR></TABLE>
yes
yes
im keeping the stock LCAs, they're not fucked up
it says on the beaks site that the Civic EX Sedans LCAs are compatible with the sway bar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK »</TD></TR><TR><TD CLASS="quote">mr choi , could that be eric choi?</TD></TR></TABLE>
no. you wont need new lca for an itr bar. it'll fit. use SI endlinks tho.
wait EX civic's came with rear bar? i though only on si. la;ksd g
Re: ITR Rear Sway on Civic EX (Mr. Choi)
it says directly on the site that it will fit a Civic EX sedan with everything they give u in the package
VBitter
10-11-2009 06:10 PM
krazy one
Suspension & Brakes
25
09-22-2007 06:46 PM
