compression test on b18c1..help...VIDEO w/ pic
so i did my compression test and I got 195,198,200,202 from left to right. BUT im thinking the gauge is foked. check out the vid doesnt move until 5th turn....im sure if i kept it going it would go higher but it looked like they toped out around ^those numbers. also look at my spark plugs...look a bit white'ish if you ask me. i hit boost 2 times by mistake and it was only 2lbs-5lbs soooo im hopeing that didnt hurt it any. reason being, im not tuned yet...RPMs still a bit jumpy too. mabye do to my 750cc injectors and a 8lb flywheel?
http://wtflip.com/guar4life/compressiontest.wmv
Took 5 turns or less on mine. Using a MAC tools comp tester that had a leak. stock GSR; compression (10.1:1), pulled 250 260 250 255. Never took more than 5 turns and that last one was just to make sure it was peaking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">the basic rule of thumb is if the numbers are consistent then they are good. the just cant go below i believe 130</TD></TR></TABLE>
exactly. Not all guages are created equal. When i had my Si, the compression numbers were 220-230 across the board (about 10.2:1 compression). When i tested my B18b engine it was 180 even across the board. I think it's fine though, what you're really looking for is consistency.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ENJOYtheRIDE »</TD></TR><TR><TD CLASS="quote">Took 5 turns or less on mine. Using a MAC tools comp tester that had a leak. stock GSR; compression (10.1:1), pulled 250 260 250 255. Never took more than 5 turns and that last one was just to make sure it was peaking.</TD></TR></TABLE>
Cheaper compression testers have a larger dead volume. This lowers the ultimate compression number and requires more stroke to fill that volume. The MAC tester is a good tool, even with the leak.
My craptastic tester reads a consistent 205 psig on my 10.3:1 GSR with ITR cams. As mentioned before, consistency is the key.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angelSIR-G »</TD></TR><TR><TD CLASS="quote">plug looks like your runnin lean
by the way compression looks ok</TD></TR></TABLE>
the plugs looks like hes burning oil( black on the inner ceramic)
The plugs on my 45 mile fresh motor look like that too, I also looked at my pistons when the plugs were out and they looked pretty black for only having 45 miles on them..... wtf is the deal there?
