Hood Pin Installation? What is this part for?
Old May 14, 2006 | 12:51 PM
bigslimdog's Avatar
Default Hood Pin Installation? What is this part for?
I'm about to install some Sparco hood pins on my CF hood and I don't know what this part is for. Obviously you screw the little screws into it but where do those little flat clip things go?
Old May 14, 2006 | 01:00 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Hood Pin Installation? What is this part for? (bigslimdog)
The flat clips are pretty much a "nut" for the screw, something extra for it to grip into.
Old May 14, 2006 | 01:09 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Hood Pin Installation? What is this part for? (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">The flat clips are pretty much a "nut" for the screw, something extra for it to grip into.</TD></TR></TABLE>
what he said
Old May 14, 2006 | 01:38 PM
Padawan's Avatar
Darth ModerVader
Default Re: Hood Pin Installation? What is this part for? (SlammedDC2)
Correct. Personally, I would prefer to use rivets, but the screws will work fine.
Old May 14, 2006 | 01:41 PM
bigslimdog's Avatar
Default Re: Hood Pin Installation? What is this part for? (Padawan)
So those clips go on the underside of the hood and the screw goes into them? Or between the hood pins and hood?
Old May 14, 2006 | 01:48 PM
Padawan's Avatar
Darth ModerVader
The clips would be used on the underside of the hood, almost in the same way that you'd use a nut on a bolt.
alacard
13
Apr 8, 2007 12:25 AM
Devo94ac
Mar 9, 2006 05:47 AM
DubyaAye
62
Sep 13, 2004 08:22 PM
layz1eviet
Apr 21, 2004 08:45 PM
Uneekpinoysk8er
12
Apr 23, 2003 10:32 PM
