help with my stereo woes
Old May 14, 2006 | 12:09 PM
g-ride-si's Avatar
Default help with my stereo woes
About a year ago my sub quit working right, it was sucking in instead of pushing and pulsing even with the volume all the way down. after checking everything else i switched my rcas from the sub output to the rear output and that fixed it. well about a week ago my sub started doing the same thing again. i have no more outputs to use and im not sure if its the outputs or my wiring.
any help is appreciated, the head unit is a 2 yr old pioneer deh p6500
Old May 14, 2006 | 02:04 PM
g-ride-si's Avatar
Default Re: help with my stereo woes (g-ride-si)
anyone?
Old May 14, 2006 | 08:24 PM
02 accord's Avatar
Unplug the RCAs from the amp and see if the sub still does that. If it does, then its your amp. If not, then its the headunit.
Old May 15, 2006 | 02:17 PM
g-ride-si's Avatar
Default Re: help with my stereo woes (02 accord)
yea i did that, i guess its the head unit. pisses me off its less than 2 yrs old.
Old May 17, 2006 | 08:10 AM
sony224422's Avatar
mine did the same thing.. its a bad ground in the headunit. Try putting a ground loop on and i bet it will stop
Old May 17, 2006 | 01:37 PM
g-ride-si's Avatar
Default Re: help with my stereo woes (sony224422)
ground loop? you mean ground the stereo to itself?
Old May 17, 2006 | 01:46 PM
sony224422's Avatar
no.. sorry here i'll find one for you.
http://search.ebay.com/Ground-...01Q20
look at those if you want..
if you can't see that i searched "Ground Loop Isolator" on ebay
Old May 17, 2006 | 02:38 PM
g-ride-si's Avatar
ah thanks, whats weird is ive had one of those for a few years now and never knew what it was. guess ill try it.
Old May 17, 2006 | 06:51 PM
sony224422's Avatar
haha, well try it out.. and hopefully it will work
jamie_honda_08
Audio / Security / Video
Oct 19, 2005 04:28 PM
JiggyKooAndy
Jun 4, 2004 05:45 AM
MisterHYBRID
Sep 22, 2003 08:45 PM
Racer X
11
Nov 13, 2002 08:27 PM
bigD
Nov 8, 2002 07:54 AM
