sensors sensors sensors
Old May 14, 2006 | 10:45 AM
3s0n3's Avatar
Default sensors sensors sensors
who what these sensors are or can just post a sensor location list for a 99gsr
what do i do with these from the crx si harness?
Old May 14, 2006 | 10:51 AM
RCautoworks's Avatar
Default Re: sensors sensors sensors (3s0n3)
#1 purge canister
#2 Plugs to the back of the manifold or its the Intake air plug ( iacv read later in this post )
#3 Map sensor
#4 Intake air temp
#5 purge canister
#6 IACV
#7 radiator fan and oil psi sensor
#8 Reverse lights, 02 sensor plug , engine coolant plug I think
#9 Intake plug I think
Old May 14, 2006 | 10:52 AM
Take some farther pics, hard to tell where some things are located.
Old May 14, 2006 | 01:52 PM
3s0n3's Avatar
what ones are hard to see where they are?
and what you wrote for #7, there is nowhere on the block for that like there was on the d16 so what i do with it?
Old May 14, 2006 | 01:54 PM
3s0n3's Avatar
and in pic 9 and 8 there are no spots on the b18 for them like there was on the d16 so what i do with those too?
Old May 14, 2006 | 01:56 PM
Default Re: (3s0n3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 &raquo;</TD></TR><TR><TD CLASS="quote">what ones are hard to see where they are?
and what you wrote for #7, there is nowhere on the block for that like there was on the d16 so what i do with it?</TD></TR></TABLE>
Look on the thermostat housing
02 sensor is different on a gsr, you will need to add wires because the o2 sensors on a d16 obd0 are single wire, gsr have 4 wires. And reverse lights are on the transmission.
Look at my reply, 9 and 4 go together.
Old May 14, 2006 | 02:13 PM
3s0n3's Avatar
lemme just get more organized here....
: you say 9 and 4 go togather. so thats done.
: what about pic 1 what wire goes there is it
one off the crx harness or the v tec sub?
:in pic 2 (better seen in pic 7) there is a small square connector and the round white one and the thing with the rubber on it. which one is the fan swich and how does it get connceted?
: pic 3 wheres the wire for that sensor on the throtle body?
: pic4 done
: pic 5 wheres the wire come from for that?
ic 6 wheres the wire come from for that?
pic 7 "disgussed earlier"
: pic 8 there are 5 things in the pic what are they individually and where do they go ?
i know im asking for a lot here but bear with me please.....
Old May 14, 2006 | 02:24 PM
Default Re: (3s0n3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 &raquo;</TD></TR><TR><TD CLASS="quote"> you say 9 and 4 go togather. so thats done</TD></TR></TABLE>
2 and 4 can also go together also, look at the plugs in pic 9 and 2, they are the same. Its all going to determine where they're located.
what about pic 1 what wire goes there is it </TD></TR></TABLE>
Are you pointing at the thing under the manifold ? Thats the purge solenoid, you will have to add wires in order to do this swap. Depending what ecu you are running.
in pic 2 (better seen in pic 7) there is a small square connector and the round white one and the thing with the rubber on it. which one is the fan swich and how does it get connceted?</TD></TR></TABLE>
The thing with the rubber boot is the fan switch plug. You will have to rewire it to so it fits the plug on the thermostat. Not sure on that tiny square plug
Look on your harness, honestly its not that hard. Only a few plugs will fit, the map sensor plug and the tps plus will switch though so watch out for that. Find out what color wires go there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 &raquo;</TD></TR><TR><TD CLASS="quote">: pic 5 wheres the wire come from for that?
Once again, you will have to rewire that because the crx harness will not have that.
Sounds like you have not done your research on this swap, search around the site a little and figure things out. Its to hard to determine some things over the internet.
Old May 14, 2006 | 03:00 PM
3s0n3's Avatar
the rywire vtec sub will take care of a few of these things i know that. but there are just a few other misc things here that i need just to know what they are then i am confident i can do the wiring. you just cant wire things you dont know what they are .
Old May 14, 2006 | 03:08 PM
Default Re: (3s0n3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 &raquo;</TD></TR><TR><TD CLASS="quote">the rywire vtec sub will take care of a few of these things i know that. but there are just a few other misc things here that i need just to know what they are then i am confident i can do the wiring. you just cant wire things you dont know what they are .</TD></TR></TABLE>
Of course, but I told you what parts were what. Now its your turn to switch for what color wires they are and such.
If it was obd0 I could tell you what plug and what color wires go where, but you are running obd1 I assume.
Old May 14, 2006 | 04:14 PM
3s0n3's Avatar
this is going to be an obd2a swap
Davesmit
Mar 31, 2019 06:52 PM
jimburt3rd
Jun 27, 2011 06:55 PM
castle1313
Feb 4, 2010 03:56 PM
SocalChris
15
Aug 21, 2005 05:32 PM
BuddyC
Apr 20, 2004 04:54 PM
