Switching intake manifold
Old May 14, 2006 | 09:38 AM
6doorsentra's Avatar
Default Switching intake manifold
I own an 88hf crx. I have an extra intake manifold from a 91crx si. I want to put it on the HF model. It should bolt right up with no problems, correct? I will be replacing the gasket with a new SI one. All help is appreciated, thanks.
Old May 14, 2006 | 07:20 PM
up
Old May 14, 2006 | 07:41 PM
Mugencrxsir1's Avatar
Default Re: Switching intake manifold (6doorsentra)
I believe they are completely two different things, the Si much different in design than the HF intake. But some one else will confirm this.
Old May 14, 2006 | 07:47 PM
downest's Avatar
Default Re: Switching intake manifold (Mugencrxsir1)
It should bolt up. I don't think you are really going to benefit from it though, the HF is designed to sip gas, that little 8 valve head isn't going to flow too much, just look at the difference between the HF and other intake arms and throttle bodies.
Old May 14, 2006 | 09:26 PM
Donkey85's Avatar
Default Re: Switching intake manifold (downest)
you wont feel any difference by doing this. get an si head then you will feel a huge difference by going from 8 valves to 16
Old May 14, 2006 | 11:03 PM
d16vtecx's Avatar
Default Re: Switching intake manifold (Donkey85)
cant use a 16 valve head with hf pistons cuz they only have 8 valve reliefs
r90crxhf
10
Apr 21, 2011 11:36 PM
CrxHf-Rider
13
Jun 5, 2006 06:36 PM
delsolsir2
Jun 14, 2004 04:36 AM
thao4life
13
Oct 10, 2002 06:20 PM
91kriks
Nov 1, 2001 06:37 PM
