Why is my FUEL CUTTING OFF at 4000RPM's sometimes??????????
Sometimes my fuel cut off be hitting at 4k rpm and its annoying not to mention potentially dangerous. Why would this be happening? Also one time it was doing it at 2k rpms.
you mean it gets like boggy feeling right wen the car doesnt go over a certain rpm? if so i got the same problem too im tryin to figure it out too
well when 4k comes i lose all power and once the revs drop down to like 3k it kicks back on. and yeah i got a CEL code 41 Primary oxygen sensor heater code and a 17 VSS - speed sensor
ok figured it out reset the ecu well first check ur 02 sensor n all ur clips make sure everything is right map sensor intake air temp sensor all the plus n sensor then reset the ecu n ur set too go
remo
Aug 15, 2006 11:51 AM
