Tranny problem
Old May 13, 2006 | 08:01 PM
EJ1_228's Avatar
Default Tranny problem
ok so I have a 90 civic with a LS swap connected to a YS1 lsd tranny, but I have a problem. I can't put the car into gear. When I push the clutch all the way down it will not go into gear. I can turn the car off and put it in gear and start it but it will go with the clutch all the way in, car anyone tell me what the problem is thanks.
Old May 13, 2006 | 09:26 PM
Mavrick's Avatar
Default Re: Tranny problem (EJ1_228)
rebleed it sounds like air or a faulty clutch cylinder
Old May 13, 2006 | 09:35 PM
EJ1_228's Avatar
no no.... it is a YS1 tranny, it's a cable clutch and I just replaced the cable thanks to hassport
Old May 14, 2006 | 05:22 AM
D Rex's Avatar
Default Re: (EJ1_228)
Why a new cable? It's most likely a clutch issue. Make sure the cable isn't binding. Tighten it up at the adjuster. Some times it takes two people one to pry on the lever and turn the nut If that don't get it inspect the clutch disk for loose material as a blown disk will do this.
Old May 14, 2006 | 07:39 AM
EJ1_228's Avatar
ok will due thanks for the advice and I'm still open for any other comments
Old May 14, 2006 | 09:47 AM
b18sihatch's Avatar
i had a ls with a s1 cable clutch tranny, same problems as you, took the tranny off, throw out bearing problem!
Old May 14, 2006 | 09:51 AM
mntuner2's Avatar
Default Re: (b18sihatch)
Did you install the clutch disc in the right way. There is a flywheel side and a pressure plate side.
bradennicely
Apr 23, 2010 07:37 AM
speedfreek128
10
Mar 28, 2008 07:45 PM
cupOjo
Jul 1, 2006 07:34 AM
tegrevboy
Oct 22, 2002 04:11 PM
