Suspension & Brakes Theory, alignment, spring rates....
ek w/itr rear sway bar, si links ????
Old May 13, 2006 | 07:22 PM
aak's Avatar
aak
Default ek w/itr rear sway bar, si links ????
i have the itr end bushings, and the collars that go with them, but the si end links are to big for the collars. anyone know what bushings/collars i need? will the stock si sway bar bushings/collar's fit in the ends of the itr bar? the endlinks will fit in the sway bar end bushings, just without the collar's in them. without the collar insert, it seems the enlink will just eat through the bushing eventually. any help is appreciated
Old May 14, 2006 | 04:24 AM
aak's Avatar
aak
Default Re: ek w/itr rear sway bar, si links ???? (aak)
mothers day bump
Old May 15, 2006 | 04:53 AM
aak's Avatar
aak
i know somebody has this set up on an ek. bump
Old May 15, 2006 | 08:00 AM
Spoon-EK9's Avatar
https://honda-tech.com/zerothread/1628011
it was just 3~4 below your post.
anyway you need special washers in order to put the si endlinks on your ITR sway bar.
Old May 15, 2006 | 10:50 AM
gabebauman's Avatar
Default Re: ek w/itr rear sway bar, si links ???? (Spoon-EK9)
I might have a spare set of these if you want to buy them from me.
I'll check when I get home from work tonight.
Old May 15, 2006 | 01:22 PM
WONG FRIED RICE's Avatar
if you get the ASR sub-frame brace it comes with those washers. Maybe look into getting ASR brace? IMO it's worth it.
Old May 17, 2006 | 06:19 AM
aak's Avatar
aak
Default Re: ek w/itr rear sway bar, si links ???? (WONG FRIED RICE)
thanks for the help. i'm definitly getting the asr brace, so that should solve the the bushing/collar problem. i just wish i didn't spend the $25 on parts i don't need , my fault. the asr is a beautiful piece, i can't wait to get mine. thanks again
Old May 22, 2006 | 09:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aak &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help. i'm definitly getting the asr brace, so that should solve the the bushing/collar problem. i just wish i didn't spend the $25 on parts i don't need , my fault. the asr is a beautiful piece, i can't wait to get mine. thanks again </TD></TR></TABLE>
u deffinately won't regret it! see .....
royalrebel
Suspension & Brakes
Dec 19, 2008 04:49 PM
JDMCRX
Apr 26, 2003 10:08 AM
Greasemonkey
14
Oct 19, 2002 07:27 AM
GokuSSJ4
10
Mar 17, 2002 11:11 PM
PhoBichNga
Feb 16, 2002 07:54 PM
