valve spring/retainer compressing question.
What Valve Spring Compressor are you guys using? I went and purchased one from Sears today and I cant seem to get it to angle properly is there a different kind/version i can pick up that will make the job easier?. Are there any Tips/Tricks to it?
The one i bought is this one http://www.sears.com/sr/javasr...e=Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 »</TD></TR><TR><TD CLASS="quote">it says it has two different jaws. one offset and one regular did u try both?</TD></TR></TABLE>
i did and had a hard time with both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91Civic_Joe »</TD></TR><TR><TD CLASS="quote">i've never seen a valve spring compressor that looks like that. </TD></TR></TABLE>
what have you seen/used cuz the only other "kind" im seeing is the Snap On one and thats like $120...
I think the one i saw id used for domestic cars and u have to bend the tabs that push down on the spring inwards (><
Knock off version of the snap-on,
http://cgi.ebay.com/ebaymotors...wItem
Equally effective for the job yet half the price!
That is a great kit but a little difficult if off the car. If the cylinder head is off the car i recomend the C-clamp type, pneumatic if you can afford it. The snap on style is great to use with an air compressor as well, you can get a hose with a fitting on the end to fill the cylinder with air, then compress the valve spring, and the compressed air in the cylinder will keep the valve from dropping.
JDM_SOHC
Mar 23, 2012 01:42 PM
