wiring an amp to stock stereo need help!
Old May 13, 2006 | 01:56 PM
Ideal's Avatar
Default wiring an amp to stock stereo need help!
hey guys im working on my friends ford focus and we are wiring in an amp and speakers to his stock deck, everything is fine, we have a converter kit to RCA etc, but we cant figure out how to get a 'power on lead' for the amp please help! or if there is a way to just have it turn on each time the car turns on, etc.... thanks!
Old May 13, 2006 | 02:56 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: wiring an amp to stock stereo need help! (Ideal)
you could tag it off you ingnition wire if neccesary, this way it comes on and off with the ingnition. Or you can grab it off the factory radio ant wire is it has one. Or put it on a switch. "Dei", makes one that automatic, When it sences out put on your speaker leads it turn the amp on. And when there is no signal it turns it off.
Modified by wrx-killer-Sti eater at 6:58 PM 5/13/2006
Old May 13, 2006 | 05:49 PM
Orangeciv's Avatar
Get a wiring diagram for yer car and just look for the 12v acc. wire, that way it'll turn on when your radio turns on, a switch is not a good idea especially if you forget it on. Check out http://www.the12volt.com they might have some info for you
delsolio1996
Jun 15, 2014 07:32 AM
rollin92
Audio / Security / Video
Nov 22, 2005 12:33 PM
1.8gsrcivic2000
Jan 20, 2005 12:32 PM
lenn
Sep 7, 2004 06:52 AM
Starrman85
Apr 15, 2003 04:24 PM
