Sunroof drain hose exit?
Old May 13, 2006 | 01:49 PM
JamieK18T's Avatar
Default Sunroof drain hose exit?
I'm trying to trace down this leak in my sedan. When I pulled up the carpet near the drivers side door, I noticed a previous owner must have been doing the same thing. The metal near where the hood release was cut. I pryed it back and saw the end of the sunroof drain hoise dangling there. Is it supposed to be like that or connect somewhere so it exits the car? I can't really see much. Where is it supposed to exit? The other side looks like it exits at the pinch weld. None of my other cars (non Honda) were like that.
Old May 13, 2006 | 01:59 PM
aXhatch's Avatar
Default Re: Sunroof drain hose exit? (JamieK18T)
my drain hose in my Si hatch, exits right behiond front wheel.
comes out a hole in the body. hope this help
coudlg et a pic if you need it maybe
Old May 13, 2006 | 02:00 PM
Targa250R's Avatar
be professional
If you have an '88-91 sedan, then your sunroof is aftermarket, so we can't really tell you how it is or isn't supposed to be.
Old May 13, 2006 | 03:17 PM
ludesrv's Avatar
I thought EX has sunroofs, maybe not. If it's aftermarket then run it in a better location.
Old May 13, 2006 | 03:21 PM
crxnj's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">I thought EX has sunroofs, maybe not. If it's aftermarket then run it in a better location.</TD></TR></TABLE>
no 4dr sedan came with a sunroof in this country..
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">I thought EX has sunroofs, maybe not.</TD></TR></TABLE>
Nope, no USDM '88-91 4dr came with a sunroof from the factory.
G0crxG0's Avatar
I've got pics of where it exits on my CRX, but cant find them.
On mine, the hose goes to the rear corners, and has a nipple type deal at the end that's removable to clean the tube. Then, the tube (with the nipple on) is inserted into a little rubber boot thing that seals it from the outside. It drips from there, right between the rear bumper and car. Thats why there's always rust on the rear of the rear wheel wells b/c the hose gets yanked out and rather then dumping out of the car, it dumps into a little crevice in the rear wheel well, and sits there. Nobody notices it b/c its all behind the interior and even then its behind the frame.
Old May 13, 2006 | 03:23 PM
crxnj's Avatar
Default Re: (G0crxG0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0crxG0 &raquo;</TD></TR><TR><TD CLASS="quote">I've got pics of where it exits on my CRX, but cant find them.
On mine, the hose goes to the rear corners, and has a nipple type deal at the end that's removable to clean the tube. Then, the tube (with the nipple on) is inserted into a little rubber boot thing that seals it from the outside. It drips from there, right between the rear bumper and car. Thats why there's always rust on the rear of the rear wheel wells b/c the hose gets yanked out and rather then dumping out of the car, it dumps into a little crevice in the rear wheel well, and sits there. Nobody notices it b/c its all behind the interior and even then its behind the frame.</TD></TR></TABLE>
thats how i got my crx..when i removed those rear panels i was in shock..
Old May 13, 2006 | 03:34 PM
G0crxG0's Avatar
Default Re: (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">thats how i got my crx..when i removed those rear panels i was in shock..</TD></TR></TABLE>
Yeah, talk about design flaw of the century, right?
If it werent for that, I'd dare say we'd have aSHITLOAD of more CRX's around.
The thought of a CRX sittin there screamin "Help, help, there's water sittin me like ima damn cup!" gives me the chills......LOL
obuhmyuh
Feb 25, 2008 04:54 PM
floatfisher
Apr 20, 2007 08:32 PM
redteg96
Jul 7, 2006 08:02 AM
cpforyou
Apr 17, 2005 04:29 PM
DC2point0
Jul 12, 2004 03:48 AM
