how to unistall rear motor mount 88-91 crx
since i dont have the right tool i always end up dropping the rear subframe,,,but i hear you just need some kind of swivel joint with an extension..
I just did it two days ago. remove the intake tube, pull the fuel filter bracket off the firewall and pull the map/soleniods off the firewall. Take a long 3/8"extension 18" or more and go thru the heater hose sw/bracket. Then put the 14mm socket on the extention while you have the extension thru the heater thing. then slide it on the bolt. It will be tight but you can do it.
This will work trust me. I didn't think I could get a socket on it either.
Oh yeah, use a small 14mm socket not a deep socket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman »</TD></TR><TR><TD CLASS="quote">I just did it two days ago. remove the intake tube, pull the fuel filter bracket off the firewall and pull the map/soleniods off the firewall. Take a long 3/8"extension 18" or more and go thru the heater hose sw/bracket. Then put the 14mm socket on the extention while you have the extension thru the heater thing. then slide it on the bolt. It will be tight but you can do it.
Oh yeah, use a small 14mm socket not a deep socket.</TD></TR></TABLE>
You know what, I think I did that way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">
thats the thing i need right there..sick and tired of dropping the subframe when i do swaps for people...
what is the exact name of that swivel thing on the end of the extension??
</TD></TR></TABLE>thats the thing i need right there..sick and tired of dropping the subframe when i do swaps for people...
AdamsAutoAdvice
May 25, 2025 05:21 PM
the.hamburglar
Jul 21, 2005 02:47 PM
AzntaggeR
Feb 14, 2004 07:31 PM
I know it's a SUPER TIGHT fit.
