acoord turbo problem
yo, iam having problem with my accord turbo charged. if there anyone in the chat with a F23 turbocharged?.................need help..........my check engine ligth dont turn off from the dash board. on first gear, it boost good, but o second gear, like on 4 or 5 RPM, the VTEC gets kill, and the car lose power, and you can feal it that is not moving as it was on first gear. the car still boost, but it lose power. Also after the VTEC dies, if i stop and then want to go again, the car acts as if it want to turn off when you hit the gas.
Modified by Lamole at 10:27 AM 5/16/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamole »</TD></TR><TR><TD CLASS="quote">my check engine ligth dont turn off from the dash board. on first gear, it boost good, but o second gear, like on 4 or 5 RPM, the VTEC gets kill, and the car lose power, and you can feal it that is not moving as it was on first gear. the car still boost, but it lose power. Also after the VTEC dies, if i stop and then want to go again, the car acts as if it want to turn off when you hit the gas.</TD></TR></TABLE>
First, get the code.
Second, what are you using for fuel management?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">First, get the code.
Second, what are you using for fuel management?</TD></TR></TABLE>
^^ what he said. what's the CEL???? then we need details on management: what ecu, what injectors, what map sensor, is it tuned?
i got the codes. it was marking the oxygen and MAP sensor. i got both replace with new ones. and still got the problem, however the codes where different after i changed the sensors...............im using 2 fuel pump, one walhbroo 255 in the tank, and a MSD outside the tank, a vortech FMU 12:1, and the stock ECU, and stock injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Its probably not tuned. He doesn't sound like he knows what he is talking about, so I doubt he knew to get it tuned.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamole »</TD></TR><TR><TD CLASS="quote">i got the codes. it was marking the oxygen and MAP sensor. i got both replace with new ones. and still got the problem, however the codes where different after i changed the sensors...............im using 2 fuel pump, one walhbroo 255 in the tank, and a MSD outside the tank, a vortech FMU 12:1, and the stock ECU, and stock injectors.</TD></TR></TABLE>
you need get a missing link and it will be all better! Your ECU is seeing boost and doesn't like it one bit. There's nothing wrong with your map sensor.
http://www.synapseengineering.....html
Install one of those and clear your ECU. You'll be all set! Happy boosting, sounds like you at least have a solid fuel supply setup for the ECU.
