How can you tell the difference between SS and Mild Steel?
Old May 13, 2006 | 08:59 AM
scartail's Avatar
Default How can you tell the difference between SS and Mild Steel?
Is there a quick way, I can tell the differenct between the two?
I've heard of a spark test. Don't exactly know what that is.
Someone suggested cleaning both, and compare the rust.
Anyone of you have an idea?
Old May 13, 2006 | 09:31 AM
RCautoworks's Avatar
Default Re: How can you tell the difference between SS and Mild Steel? (scartail)
Magnet won't stick to stainless.
Old May 13, 2006 | 09:56 AM
silentdaredevil2's Avatar
^ correction, depending on the series of stainless a magnet might have a slight pull to it but not a whole lot. Mild steel a magnet will cling fast to solidly
Old May 13, 2006 | 10:02 AM
k24em2's Avatar
Default Re: (silentdaredevil2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdaredevil2 &raquo;</TD></TR><TR><TD CLASS="quote">^ correction, depending on the series of stainless a magnet might have a slight pull to it but not a whole lot. Mild steel a magnet will cling fast to solidly</TD></TR></TABLE>
Or you can get real fancy with one of those metal analyzers.
Old May 13, 2006 | 11:21 AM
scartail's Avatar
I'll try the magnet trick... But the idea is that there would be a pull difference... Right? Thanks guys.
Old May 13, 2006 | 11:51 AM
weiRtech's Avatar
OG Fabricator
Default Re: (scartail)
spark test: take a known peice of mild steel and grind it on a bench grinder, you will get a big rooster tail of sparks. with ss you will get a small amount to almost no sparks.
Old May 15, 2006 | 05:42 PM
scartail's Avatar
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">spark test: take a known peice of mild steel and grind it on a bench grinder, you will get a big rooster tail of sparks. with ss you will get a small amount to almost no sparks.</TD></TR></TABLE>
It think that is quite practical. Most people will have a way of grinding/cutting something (dremel, grinding wheel, cutoff saw, etc) around.
Thanks.
Old May 15, 2006 | 05:59 PM
SMSP's Avatar
300 series stainless are non magnetic, 400 series are magnetic
Old May 15, 2006 | 09:19 PM
own6volvos's Avatar
Maybe try a overnight corrosion test in some hot salt water
Old May 15, 2006 | 09:26 PM
AceRaceParts's Avatar
Default Re: (own6volvos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by own6volvos &raquo;</TD></TR><TR><TD CLASS="quote">Maybe try a overnight corrosion test in some hot salt water </TD></TR></TABLE>
Even 304 will corrode in hot salt water.
HT Chaplain
Welding / Fabrication
Jan 25, 2008 06:23 PM
shortyz21
Oct 23, 2007 05:41 AM
just Touge
Jul 2, 2007 10:24 AM
BlueLude94
Dec 25, 2005 10:20 PM
Evo-man@20psi
32
Mar 28, 2005 02:53 PM
