What Transmission?
any will be fine. depends on where you do most of your driving. i recommend the B16 tranny w/ the LS 5th if you drive highway often, especially w/ boost, the higher rpm on the highway will cause alot of heat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackEK4coupe »</TD></TR><TR><TD CLASS="quote">I am planning on a GSR Block, mated with a B16 head. Which tranny would be best for the boost? I was thinking the S80. Any suggestions?</TD></TR></TABLE>
"S80" covers like, every G3 Integra manual transmission.
How much power/torque are you planning on making?
Ideally you want the shortest geared tranny you can get, but if you're making 800hp, that's probably not the ideal setup for maximizing traction.
tomlinson619
Jun 2, 2006 01:58 PM
bboylito
Oct 30, 2004 02:34 PM
