Searched,Found nothing, ya can you believe it....NOTHING!!!
Seriously though, there was a pretty good tutatorial post on removal of window crank handles. If any one runs across this or has any good suggestions on how to remove the window crank handles let me know.
I know this isn't brain surgery.....but I don't need not to screw up the good set of Si door panels that I transfering over from my newly purchased beater.
As always, thanks guys
if u kinda push the panel back a little behing the window roller, you should notice a clip... pop off the clip... then, BANG! ur good to go bro
The method described in said post was explaining the way of using a rag or tshirt. It's in the manuals I believe.
IDK I tried it, didnt work 4 me. I just do like he said only with pliers. It not that hard, probably the first thing I ever did to my CRX.
https://honda-tech.com/zerothread?id=1576165
searched for "window crank"....is that what you can't find?
B18cHatch06
Jul 18, 2007 08:36 PM
TenLarge
Jun 18, 2005 01:37 PM
civicrtype2
Mar 5, 2005 11:54 PM
Mentat Ghola
Jan 11, 2003 04:47 PM
