Engine Pictures. Critique needed.
Old May 12, 2006 | 11:14 PM
gawath's Avatar
Default Engine Pictures. Critique needed.
Took the head off of my motor to inspect a few things and took some pictures. The motor has CP pistons/stock rods and has been broken in for ~1500 miles. Just want to know if you guys see any issues that I may not have found from my inspection. I noticed a lot of buildup on the top of the pistons and oil. I’m not too sure where the oil may be coming from. The cross hatch from the hone is still showing.
Head - Cylinder 1
Cylinder 1 Exhaust Port
Cylinder 1 Intake Port
Head – Cylinder 2
Cylinder 2 Exhaust Port
Cylinder 2 Intake Port
Head – Cylinder 3
Cylinder 3 Exhaust Port
Cylinder 3 Intake Port
Head - Cylinder 4
Cylinder 4 Exhaust Port
Cylinder 4 Intake Port
Cylinder 1 Top
Cylinder 2 Cross Hatch
Cylinder 3 Cross Hatch
Cylinder 4 Top
All four Cylinders
Valve area
Old May 13, 2006 | 12:03 PM
Combustion Contraption's Avatar
Engine looks to be running very hot/lean and from the looks of the design of the piston i would say this is a forced induction setup. I would check the valve stem seals on the intake side, specifically cylinder #4.
Old May 13, 2006 | 03:41 PM
gawath's Avatar
Default Re: (Combustion Contraption)
Thanks for the information. I'm thinking that oil is getting in through the intake valve side (valve stems like you suggested). It's creating a lot of heat in the combustion chamber and making the exhaust valves look like that.
t0ng0
Apr 9, 2014 12:26 PM
D16honda
Apr 10, 2010 05:59 AM
badream20
Apr 24, 2008 04:31 PM
turbotime
Nov 2, 2006 11:06 AM
deascendent
Apr 3, 2004 08:39 AM
