compression ratio seem high?
Old May 12, 2006 | 10:44 PM
Orangecivic251's Avatar
Default compression ratio seem high?
ok guys i've been trying to order parts and i'm a little confused here i used the http://www.zealautowerks.com/ compression calculator
i'm using a
p72- gsr head (has aftermarket valve springs and retainers
buddy club spec 4 cams
b18b bottom end
z10 3 main block girdle
ctr 81.50mm pistons
b18b rods not sure which ones to run
oem headgasket
stock crank
my thing is the calculators saying i'm gonna have 14.38 compression ratio is this thing correct i heard it gives you lower numbers so i'm a little worried that seems high
Old May 14, 2006 | 06:27 PM
Default Re: compression ratio seem high? (OrangeCiviC251)
any help with this
Old May 14, 2006 | 06:42 PM
97L-esVeeTeg's Avatar
https://honda-tech.com/zerothread?id=717928
^^^^^^^^^ First, take a look at that.
Anyway, yeah that does seem high, around ~13.4 sounds about right.
Old May 14, 2006 | 07:12 PM
B18cHatch06's Avatar
Default Re: compression ratio seem high? (97L-esVeeTeg)
id be worried either way if this was a daily driver...it will need more than 93 octane and a good tune
Old May 14, 2006 | 07:15 PM
Default Re: compression ratio seem high? (B18cHatch06)
well here in tenn we get 93 octane so no big deal and i plan to take it to either atlanta or a guy in alabama to tune it on hondata
Old May 14, 2006 | 07:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cHatch06 &raquo;</TD></TR><TR><TD CLASS="quote">id be worried either way if this was a daily driver...it will need more than 93 octane and a good tune</TD></TR></TABLE>
ahh and this is for my hatch so it will not be my daily driver. i drive my dc2 everyday
Old May 14, 2006 | 07:26 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeCiviC251 &raquo;</TD></TR><TR><TD CLASS="quote">well here in tenn we get 93 octane so no big deal and i plan to take it to either atlanta or a guy in alabama to tune it on hondata</TD></TR></TABLE>
jw whom in AL your gonna get it tuned by?
Old May 14, 2006 | 07:49 PM
LSVTEC 91 Civic's Avatar
Banned
IMO you'd be better off with a P30 piston.. more squench area and it's a lighter piston.
If you had better fuel than just pump gas to tune it.. That would work, if not, you'd be better off running the P30s instead of pulling lots of timing out.
Old May 15, 2006 | 06:07 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">IMO you'd be better off with a P30 piston.. more squench area and it's a lighter piston.
If you had better fuel than just pump gas to tune it.. That would work, if not, you'd be better off running the P30s instead of pulling lots of timing out.</TD></TR></TABLE>
Like he said, run a p30 piston.
Old May 15, 2006 | 11:38 AM
Default Re: (mar778c)
ok i'll take that into consideration
mhewitt
Jun 28, 2010 07:30 PM
hondachris1994
37
Dec 27, 2008 09:44 PM
realis9
31
Apr 3, 2007 06:13 PM
jaredfmn
Nov 18, 2002 07:25 PM
InfamousRS
Jan 14, 2002 07:07 AM
