VSS Signal Question
Old May 12, 2006 | 04:07 PM
SVOboy's Avatar
Default VSS Signal Question
So I'm trying to hook up something electronic that runs off the VSS. My friend has done so successfully on his Del Sol, but I can't get the VSS portion to work.
What I'm wondering is if this needs to have an electronic signal, where can I get that signal in my 91 CRX? I am told it gets converted to digital somewhere, but I dunno where.
I have an OBD1 ecu swap if that matters.
Thanks.
Old May 12, 2006 | 05:10 PM
VegaS10's Avatar
Default Re: VSS Signal Question (SVOboy)
On the FACTORY ecu plugs, it's pin B16 yellow with a red stripe.
What ya hooking up?
Old May 12, 2006 | 05:13 PM
SVOboy's Avatar
That pin (on the obd1 side of things) isn't doing it for me. I think I might need an electronic VSS.
It's an MPG gauge, custom made by a guy in Japan for his friend's Prius (he now uses it with his Del Sol).
He had it custom made though because the Prius gauge doesn't register above 99.9 MPG but this goes up to 235 MPG or something like that.
The injector duration and everything else works, I'm just not getting a good VSS signal.
Old May 12, 2006 | 06:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">
pin b10 at the ecu.
Old May 12, 2006 | 06:48 PM
SVOboy's Avatar
Default Re: VSS Signal Question (Chiovnidca)
it does not work on that pin
Old May 12, 2006 | 06:58 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">it does not work on that pin</TD></TR></TABLE>
Does it have a 5volt reference voltage?
Old May 12, 2006 | 07:23 PM
SVOboy's Avatar
I will have to hook up a dmm and see&lt; i spose
the vss works fine so i just assumed it was working&lt; i"ll check it in the morning&gt;
Old May 12, 2006 | 07:41 PM
Chiovnidca's Avatar
the vss works fine so i just assumed it was working&lt; i"ll check it in the morning&gt;</TD></TR></TABLE>
Are you running a cable speedo? Or did you convert it to electronic?
Old May 12, 2006 | 07:43 PM
SVOboy's Avatar
Cable, which is what makes me think that's the prollem.
I'm picking up an engine/tranny tomorrow, so I'll just use that electronic VSS I guess. I rushed the pick up just for that little VSS, I want my gauge to work!
Thanks for all the help.
Old May 12, 2006 | 07:58 PM
Chiovnidca's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Cable, which is what makes me think that's the prollem.
The speedo is cable driven. The signal that goes to the ecu is seperate from that. (but driven by the cable too) It needs a 5 volt reference to work.
Eran
14
Feb 20, 2023 09:08 PM
jlk16188
Aug 1, 2012 08:42 AM
almostjdmeg
Jan 14, 2010 09:56 PM
froger
Nov 17, 2006 07:01 AM
