89 tranny case vs 90 tranny case?
Old Apr 11, 2002 | 05:51 AM
keithv's Avatar
Default 89 tranny case vs 90 tranny case?
ok i'm on a mad search to see what tranny case i can use to cure my differential problem. the diff rubs the tranny case and i shimmed it properly. it seems the bearings for some cases are different. see my post here: https://honda-tech.com/zerothread?id=160321
so the questions i have is this: is the 89 civic si tranny case and the 90 civic si tranny case the same?
note: according to http://www.hondaautomotiveparts.com the 89 civic si uses an 80mm diff shim and the 90 civic si uses a 72mm diff shim. so is the 89 si tranny the odd ball?
thanks!
hatch_kidb18b1
Aug 12, 2009 06:01 PM
sohcvtechatch90
Jan 28, 2007 02:44 PM
thevtecnician
11
Nov 2, 2003 09:20 AM
synergy-blue
Sep 16, 2002 09:55 AM
