b16 smokes only in vtec?
Old May 12, 2006 | 12:53 PM
nekoabandoned's Avatar
Default b16 smokes only in vtec?
ok it runs great but when it hits vtec it smokes, is that normal ? thanks
Old May 12, 2006 | 12:56 PM
cambopheonix56's Avatar
Default Re: b16 smokes only in vtec? (nekoabandoned)
What color smoke? I am assuming blue from the exhaust?
Old May 12, 2006 | 12:59 PM
Default Re: b16 smokes only in vtec? (cambopheonix56)
grayish kinda maybe a little blue (i think its oil )
Old May 12, 2006 | 01:01 PM
Yea oil is normal
Old May 12, 2006 | 01:03 PM
are you being serious ? if so y does vtec burn oil?
Old May 12, 2006 | 01:20 PM
sicones's Avatar
vtec should not burn oil, your car has a problem.
Old May 12, 2006 | 01:27 PM
Walterronny's Avatar
Default Re: b16 smokes only in vtec? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">vtec should not burn oil, your car has a problem.</TD></TR></TABLE>
x 2
Old May 12, 2006 | 02:03 PM
JdmLub's Avatar
Default Re: b16 smokes only in vtec? (Walterronny)
u check ur cell codes??
Old May 12, 2006 | 03:03 PM
Default Re: b16 smokes only in vtec? (JdmLub)
no cels
Old May 12, 2006 | 03:12 PM
BlueIntegraBoy's Avatar
You lose a little oil in VTEC
Old May 12, 2006 | 03:19 PM
Default Re: b16 smokes only in vtec? (BlueIntegraBoy)
coo, ill do a compresion test tonight just to be safe thanks guys
Old May 12, 2006 | 03:23 PM
swoyEKr.'s Avatar
Try a leak down test. If your rings are good then depending on how white the smoke is it may be coolant from a headgasket leak or something. Odd's are that the rings are worn and letting a little oil by. As long as there isnt gob's of smoke flying out the back of your car then you're fine.
hurleyrob
14
Jun 27, 2006 09:51 PM
LSracing94
Jun 11, 2006 02:33 PM
fabe85
Nov 27, 2004 11:30 PM
itr1235
Oct 12, 2004 10:56 PM
SLOAZZ95
11
Jun 18, 2004 03:36 PM
