what rod for cast aluminum honda parts?
Old May 12, 2006 | 12:07 PM
dfoxengr's Avatar
Default what rod for cast aluminum honda parts?
what tig rod are you using for stock intake manifolds and block/tranny pieces?
or what kind of aluminum are these pieces?
Old May 12, 2006 | 01:17 PM
Motorhead_AZ's Avatar
Default Re: what rod for cast aluminum honda parts? (dfoxengr)
I use 5356 for intake manifolds. It's good for cast aluminum.
Old May 12, 2006 | 03:22 PM
k24em2's Avatar
Default Re: what rod for cast aluminum honda parts? (Motorhead_AZ)
I've used some 4043 on a honda trans casing. Seemed to work alright. Cast welds dirty no matter what rod you use...if you get cracking with a 5356 try a 4043 rod.
Old May 12, 2006 | 04:45 PM
dfoxengr's Avatar
Default Re: what rod for cast aluminum honda parts? (k24em2)
anyone else...trying to get the right rod the first time. lol...
Old May 12, 2006 | 05:35 PM
RMF
Guest
Posts: n/a
There is NO right rod for cast JAP ****.They put titanium dust in with the alum..It makes to tough and also so you don't weld on it .You buy a new one.There is nothing you can do about the bubbles.What I have found to work the best for me is to try and keep the piece as cool as you can.The hotter it gets the more it bubbles.And just keep shoving the rod in.
Old May 12, 2006 | 05:46 PM
tony1's Avatar
Default Re: what rod for cast aluminum honda parts? (RMF)
haha, damn, i feel better. I thought it was just me. Welding AN fittings on honda waternecks sucks!! lol
Old May 12, 2006 | 05:57 PM
RMF
Guest
Posts: n/a
Default Re: what rod for cast aluminum honda parts? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">haha, damn, i feel better. I thought it was just me. Welding AN fittings on honda waternecks sucks!! lol</TD></TR></TABLE> HA HA it is you ,I was just kidding....
That **** sucks.Even the motorcycle and jet ski cases are made with that crap.
Old May 12, 2006 | 05:58 PM
tony1's Avatar
lol, when you coming down here to school me on my welder?
Old May 12, 2006 | 07:11 PM
Niles's Avatar
There's usually a ton (relatively speaking) of magnesium in AL castings from Japan. Such a heavily alloyed metal is a bitch. I don't even bother, partly because I know its tough, partly because I suck anyway. German Aluminum for some reason seems to weld ok though.
Old May 12, 2006 | 07:13 PM
ManBearPig4silly's Avatar
Yeah it pretty much sucks to weld that crap.
I kind of prefer to use 5356 for some reason that isn't really clear to me but I just use it because I want to
Most horrible thing i've ever welded was putting an IAT sensor fitting cut off of a z6 manifold onto the back of a d16y8 intake manifold. Cast to cast for the goddamn lose.
Thank god for dremels and sanding attachments
Old May 12, 2006 | 09:04 PM
dfoxengr's Avatar
Default Re: (I4sillypwr)
so what kind of base Al are these parts then?
Old May 13, 2006 | 11:35 AM
dfoxengr's Avatar
Default Re: (dfoxengr)
anyone else?
any tips for welding this stuff?
-derek
Old May 13, 2006 | 11:51 AM
k24em2's Avatar
Hope and pray
Old May 13, 2006 | 04:09 PM
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Hope and pray</TD></TR></TABLE>
That you get lucky.
Seriously.
Old May 14, 2006 | 05:42 AM
Hondaen's Avatar
If this **** is so hard to weld becouse of the alloy, why dont attac this from a different view.
Cut out fine strings/welding material from a similar engine/tranny/whatever and try to weld using this material. Now both the materials has the same alloy and maybe it will weld up better.
Just a thought
Old May 14, 2006 | 07:09 AM
Default Re: (Hondaen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaen &raquo;</TD></TR><TR><TD CLASS="quote">If this **** is so hard to weld becouse of the alloy, why dont attac this from a different view.
Just a thought </TD></TR></TABLE>
I doubt that will work any better.
Old May 14, 2006 | 09:15 AM
Hondaen's Avatar
Why ?
Atleast you are not welding two different materials together.
Old May 14, 2006 | 10:20 AM
k24em2's Avatar
Yea but you're welding with two shitty alloys vs welding with one good one.
Old May 14, 2006 | 10:25 AM
dfoxengr's Avatar
and itd definitely be a pita to cut strips out of an old casing, lol.
Old May 14, 2006 | 11:42 AM
Hondaen's Avatar
So these "bubles" appear just by heating up the alloy with a TIG torch ?
It would be fine if someone tryed melting two similar "shitty" alloys together with a TIG torch, since the teoretical arguments why this don`t work are kinda weak.
Old May 14, 2006 | 05:08 PM
It doesnt matter that they are similer it matters that they are shitty.
If you can prove us wrong and show us a better way to do it then by all means do so.
Old May 14, 2006 | 07:46 PM
TurboJesse
Guest
Posts: n/a
Default Re: what rod for cast aluminum honda parts? (Niles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Niles &raquo;</TD></TR><TR><TD CLASS="quote">There's usually a ton (relatively speaking) of magnesium in AL castings from Japan. Such a heavily alloyed metal is a bitch. I don't even bother, partly because I know its tough, partly because I suck anyway. German Aluminum for some reason seems to weld ok though. </TD></TR></TABLE>
Ive had an easier time on the jap stuff than some vr6 parts i did. who knows though they might have been made in mexico lol
Old May 14, 2006 | 09:37 PM
RMF
Guest
Posts: n/a
Default Re: what rod for cast aluminum honda parts? (TurboJesse)
I just spent about 2 hours looking at every welding die cast page on the Internet.And did not learn anything that i didn't know. In conclusion NO there is no right way to weld die cast. Its designed to have those bubbles for light weight and strength.
Old May 14, 2006 | 11:05 PM
Niles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJesse &raquo;</TD></TR><TR><TD CLASS="quote">Ive had an easier time on the jap stuff than some vr6 parts i did. who knows though they might have been made in mexico lol </TD></TR></TABLE>
hahahha, maybe, good thinking. I've only ever welded little things on BMW and Merc heads. Maybe the VW/Audi/Porsche stuff is different? I think this is why the guys who are really good at welding heads charge the rates they do...
Old May 15, 2006 | 09:12 AM
RMF
Guest
Posts: n/a
hahahha, maybe, good thinking. I've only ever welded little things on BMW and Merc heads. Maybe the VW/Audi/Porsche stuff is different? I think this is why the guys who are really good at welding heads charge the rates they do... </TD></TR></TABLE>
Its not on heads that you have the problem.Its only on die cast parts.Like valve covers and brackets and ****
mymeatb18"
Feb 28, 2006 05:35 AM
boostedcivicsir
Welding / Fabrication
Jan 29, 2006 11:46 AM
l2yanE
Jul 23, 2005 09:10 PM
d16dcoe45
12
Jul 13, 2005 06:58 PM
boosted3g
Jan 15, 2003 04:48 PM
