Need Help on Sohc And Vtec Sohc
Old May 12, 2006 | 05:36 AM
Nicaraguense13's Avatar
Default Need Help on Sohc And Vtec Sohc
I got a 98 civic hatch one of my valves is done so i wanna make a swap instead of fixing it i got a stock SOHC non vtec i think its a OBD 2 wanted to go sohc Vtec was wondering if their is any motor that would juss pop in with my sohc non vtec wiring tranny and mount that wont make my life harder need help
Old May 12, 2006 | 05:39 AM
EJ8beast's Avatar
Default Re: Need Help on Sohc And Vtec Sohc (Nicaraguense13)
Bro if its just your valves and you want to go VTEC, why don't you try a mini me swap? Cheaper than a full SOHC VTEC swap and it'l output the same power
https://honda-tech.com/zerothread?id=554053 Read up on it
But let me warn you.. SOHC VTEC sucks =P
Old May 12, 2006 | 06:11 AM
axtran's Avatar
you can mini me, or D16Y8's were sohc vtec and obd2
Old May 12, 2006 | 06:37 AM
schardbody's Avatar
yes any obd1 or obd2 vtec motor will pop right in, but wiring will have to change, either way to run vtec you need a new ecu and wiring to the vtec solenoid and pressure switch.
Old May 12, 2006 | 08:06 AM
Default Re: (schardbody)
would a d16z6 head fit my engine is a D16y7
Old May 12, 2006 | 08:25 AM
schardbody's Avatar
yes
Old May 12, 2006 | 08:27 AM
sivik_outkast's Avatar
Just plop you an ex head on that setup, change your intake manifold, engine harness, ecu, and in dash harness for ease. Also, there will be some tricky wiring for your driver door sill connection. I did this on mine. Works great.
BTW, get you an ex gauge cluster so you got a tach
Old May 12, 2006 | 08:29 AM
I also forgot, replace your tranny with an y8 or z6 tranny. It will make a difference. This is not required, but I'm telling you from experience that it will make a difference in how it pulls.
Old May 12, 2006 | 09:26 AM
Default Re: Need Help on Sohc And Vtec Sohc (sivik_outkast)
was wondering A p28 is that Obd 1 or is their a obd 2 P28 ?????? if it is dont i have to change my whole Engine harness cuz its OBD 2???????/ or is will it plug in right and the only thing i will have to mod is the Solenoid
Old May 12, 2006 | 09:38 AM
also was wondering on the Timing Belt for a d16z6 it come off a 92-95 del sol ?????
Old May 12, 2006 | 09:42 AM
5lugSlug's Avatar
Default Re: Need Help on Sohc And Vtec Sohc (EJ8beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8beast &raquo;</TD></TR><TR><TD CLASS="quote">But let me warn you.. SOHC VTEC sucks =P</TD></TR></TABLE>
doenst suck, just cant tell if its working or not
and most, if not all d series parts are interchangeable
Old May 12, 2006 | 09:49 AM
Default Re: Need Help on Sohc And Vtec Sohc (EJacul8)
Ok.......... was wondering about the ECu if a P28 would make this harder since my car is Obd 2 and the p28 is obd 1 and also the D16z6 timing belt does it come off a 92-95 del sol ?
Jap_Spec_Imports
Apr 13, 2008 09:03 PM
tigueremalo
Aug 5, 2006 08:40 AM
btcca4
Aug 12, 2004 12:45 AM
btcca4
Aug 12, 2004 12:40 AM
Civic_Pilot
Apr 23, 2003 05:18 PM
