unorthodox pulleys vs ebay
Old May 12, 2006 | 01:42 AM
tekstyle's Avatar
Default unorthodox pulleys vs ebay
what is the difference between the UR and the no name ebay crank pulleys? from my understanding, they are all aluminum built with no harmonic dampening. so shouldnt they all be essential the same stuff?
Old May 12, 2006 | 04:24 AM
jdm_bones's Avatar
Default Re: unorthodox pulleys vs ebay (tekstyle)
don't get them the UR stress the engine, and the ebay pullyssuck a$$...Buy the CTR N1 pulley from http://www.hmotorsonline.com...They are the best, and about a 3rd of the price of a UR pulley...
Old May 12, 2006 | 06:34 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Leave it stock. Don't mess with your crank pulley on a stock motor, those other ones are not dampened and will expletive your motor up over time. If you want more power for no money, remove your P/S & A/C.
Old May 12, 2006 | 07:04 AM
gr_electronics's Avatar
Default Re: unorthodox pulleys vs ebay (Tim2179)
i have a brand new UR for a 94-01 GSR b18
never taken out the box before i sold my gsr
sell it for 60$
wich is way cheap
gr_electronics@yahoo.com
Old May 12, 2006 | 07:11 AM
jdm_bones's Avatar
Default Re: unorthodox pulleys vs ebay (gr_electronics)
Keep it stock...
Old May 12, 2006 | 07:51 AM
DC2 Mang's Avatar
Default Re: unorthodox pulleys vs ebay (jdm_bones)
both of them are garbage
keep it OEM, if you want a light pulley get the ITR or CTR pulley
Old May 12, 2006 | 08:28 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">what is the difference between the UR and the no name ebay crank pulleys? from my understanding, they are all aluminum built with no harmonic dampening. so shouldnt they all be essential the same stuff?</TD></TR></TABLE>
The primary difference, I would think, would be the quality of manufacture and materials. UR normally keeps tight tolerances and balance, and while the less expensive eBay versions might too, there is less certainty. The UR Tuner Series is a relatively inexpensive option, and you might also want to check the "Specials" section of the UR website, where you can often find very good pricing on cosmetically blemished or overstocked pulleys.
And pay no attention to the misinformed "CTR N1" crowd that recommends the N1 pulley but denounces the UR pulley in the same sentence.
Old May 12, 2006 | 11:56 AM
tekstyle's Avatar
Default Re: unorthodox pulleys vs ebay (Padawan)
what about the ITR pulley. someone said it was lighter. don't know if the gain is noticeable tho. is the CTR dampened?
Old May 12, 2006 | 03:14 PM
Padawan's Avatar
Darth ModerVader
The ITR pulley is a different part number than the GS-R pulley, though I haven't seen any weight comparisons between the two. From handling the ITR pulley, I can state that it certainly isn't "lightweight", and I doubt that the differences between it and other Integra pulleys are performance-based (perhaps something related to the ITR's different alternator).
The CTR pulley that most people commonly recommend is the N1 factory racing pulley. It is a solid pulley (just like the UR) that eliminates the AC and power steering belts. I prefer the UR because it allows the retention of AC and or power steering, is a bit lighter than the CTR N1, and also slightly under-drives.
Old May 12, 2006 | 07:06 PM
black98gsr-t's Avatar
their is nothing wrong with the ur pulleys ive been running them for almost 3 yrs daily driven and taking long trips. first installed them on stock gsr motor then boosted it , broke piston ring lands then transfered oil pump to another lsvtec swap and still boosted stock oil pump with 83,000 miles and stock gears.. the motor sees 8,000 rpm almost daily ... this has been my experince with ur pulleys (3 piece kit) i believe that most people have problems when they run high rpms for long times (freeway runs) i stick to the 1320 so maybe thats why mine still lasts...
Old May 12, 2006 | 11:49 PM
DC2 Mang's Avatar
Default Re: unorthodox pulleys vs ebay (black98gsr-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t &raquo;</TD></TR><TR><TD CLASS="quote">their is nothing wrong with the ur pulleys ive been running them for almost 3 yrs daily driven and taking long trips. first installed them on stock gsr motor then boosted it , broke piston ring lands then transfered oil pump to another lsvtec swap and still boosted stock oil pump with 83,000 miles and stock gears.. the motor sees 8,000 rpm almost daily ... this has been my experince with ur pulleys (3 piece kit) i believe that most people have problems when they run high rpms for long times (freeway runs) i stick to the 1320 so maybe thats why mine still lasts...</TD></TR></TABLE>
youre lucky then, my friend cashed out two motors with an unorthodox pulley
if you get them it is an absolute must to get them balanced
Old May 13, 2006 | 01:33 AM
tekstyle's Avatar
Default Re: unorthodox pulleys vs ebay (JDMdc2lsVtec)
seeing how i probably don't have the time and effort to maintain a pulley mod, i guess i'll stay stock. thanks for everyone's input. moderator can close this thread.
Old May 13, 2006 | 07:26 AM
Padawan's Avatar
Darth ModerVader
You don't have to "maintain" a pulley mod any more so than the factory pulley. With regard to the two engines that "cashed out", I suspect there was more that contributed to their demise than simply the use of the UR pulley. Many, many people (think how many UR and similar pulleys have been sold over the years) run these pulleys, and if they were regularly destroying engines, one can assume there would be many more accounts of such issues.
Of course, there is still no conclusive evidence that the pulleys do or do not contribute to accelerated bearing wear, and there have been a great number of threads here on H-T where both sides of the argument have been discussed in depth. In the end, it's up to the individual to examine the arguments, information, and evidence (or lack thereof), and arrive at his or her own decision about running such a pulley. It seems you've decided to stick with stock, which is perfectly acceptable.
Old May 13, 2006 | 08:03 AM
DC2 Mang's Avatar
All i know is I would never put one on my motor and I would advise anyone else to do the same
Old May 13, 2006 | 08:11 AM
no2unenolife's Avatar
oem for me
Old May 13, 2006 | 08:15 AM
DC2 Mang's Avatar
Default Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">oem for me</TD></TR></TABLE>
Old May 13, 2006 | 09:14 AM
SlammedDC2teg's Avatar
Default Re: (JDMdc2lsVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Id go with oem, Then you know that your not going to spin a bearing.
sas-Lude
Nov 5, 2006 07:39 PM
stockcolt
Jul 14, 2006 06:27 AM
chu77
Jul 3, 2006 12:51 PM
OMG WTF
Jan 15, 2006 06:54 PM
som3on3_10
11
Apr 10, 2005 07:10 PM
