help GSR cylinder one not working
Old May 11, 2006 | 07:34 PM
killalude03's Avatar
Default help GSR cylinder one not working
i have a problem that i can't figure out, cylinder one isn't working, it has great compression, has sparking from wires, looks like fuel is going into the cylinder but its not doing anything, can anyone give me a idea why it isn't working, the rest of the other 3 are working great besides this one
Old May 11, 2006 | 07:49 PM
Snafubmx234's Avatar
Default Re: help GSR cylinder one not working (killalude03)
It's sparking from the wire? You say it "looks" like you have fuel, but have you actually seen it? Verify that the plug is firing by putting it next to a ground, or using those fancy indicators. Make sure your injector is plugged in.
Old May 11, 2006 | 07:52 PM
Default Re: help GSR cylinder one not working (Snafubmx234)
sorry i meant firing from the spark plug, yes it is firing and everything, see i just bought this gsr and its at my friends shop, he told me engine one isn't working and it has great compression, fuel is questionable but i guess it is there, and spark plugs fire, other than that i have no clue
Old May 11, 2006 | 09:48 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
What kind of compression testing is he doing... if you are on tdc then you may not be getting the same results as a running compression test. A lot of times the cylinder will have perfect compression at tdc but due to wrong timing or other issues it might not be right still.
Check your ignition timing or pull the valve cover off and see if you have an internal problem.
Old May 12, 2006 | 03:05 PM
tried switching injectors so i know there is fuel
Old May 13, 2006 | 08:30 PM
Ruben19's Avatar
do a leak down test.
verify that your #1 injector is working
Old May 13, 2006 | 09:06 PM
dc5_integra's Avatar
It could be your timing. Everything could be working but doing it all at the wrong time.
Old May 13, 2006 | 10:01 PM
Default Re: help GSR cylinder one not working (dc5_integra)
figured it out after some trial and error, it was the stupid intake manifold gasket, that thing was blown to hell on cylinder one and that was the reason why it didn't work...thanks for the help everyone
Old May 14, 2006 | 06:42 PM
Dang thats crazy... at least you figured it out. Thats seems odd that your im gasket was bad though...
civic90hatch
Mar 16, 2011 01:09 PM
thunderboy
Apr 24, 2010 08:39 AM
Calvinator
Jul 21, 2006 02:29 AM
Streetracer4life128
Jul 2, 2006 03:12 PM
spliffsta2
Jun 14, 2006 06:35 AM
