b20vtec problems, blowing of oil filter seal
Old May 11, 2006 | 06:38 PM
alloutmotor's Avatar
Default b20vtec problems, blowing of oil filter seal
hey we just put together a b20vtec and it has so much oil pressure that it is blowing of the the oil filter seal
this recently happened after we changed the piston rings any one has any insight
if u need me to put more information i will
Old May 11, 2006 | 07:03 PM
Chillinit's Avatar
Default Re: b20vtec problems, blowing of oil filter seal (alloutmotor)
what piston rings are you running?
How is the surface where the oil filter seal sits?
Old May 11, 2006 | 07:39 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: b20vtec problems, blowing of oil filter seal (Chillinit)
Not trying to insult your intelligence here....
You dont have more than one oil filter o-ring do you?
Old May 11, 2006 | 10:01 PM
Default Re: b20vtec problems, blowing of oil filter seal (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to insult your intelligence here....
You dont have more than one oil filter o-ring do you? </TD></TR></TABLE>
no, only one it kept blowing of on the dyno, we checked and double checked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">what piston rings are you running?
How is the surface where the oil filter seal sits? </TD></TR></TABLE>
its sitting on a golden eagle kit
we are using je piston/rings
oil also seeps out by the head gasket near the dizzy,
note. this happened just recently, the motor was running fine before, but it had a bit of piston slap, we removed the head and the pistons and installed new rings with a tighter gap, we are now running 14/16 on the gap
Old May 12, 2006 | 06:35 AM
b19coupe's Avatar
What kind of PCV system are you running?
Old May 12, 2006 | 07:52 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloutmotor &raquo;</TD></TR><TR><TD CLASS="quote">
its sitting on a golden eagle kit</TD></TR></TABLE>
Possible the plate could be warped? Bad plate maybe?
Old May 12, 2006 | 09:09 AM
PURPLETERROR aka BIGMATT's Avatar
how much oil pressure are you getting? Did the oil feed line to the head get kinked?
Old May 12, 2006 | 09:15 AM
DonF's Avatar
Default Re: b20vtec problems, blowing of oil filter seal (PURPLETERROR aka BIGMATT)
Your relief valve in the oil pump is stuck.
Old May 12, 2006 | 11:37 AM
Default Re: b20vtec problems, blowing of oil filter seal (DonF)
thats what some one at the shop suggested about the relief valve, i think we are running a z10 pcv system
DelsolVted
14
Mar 15, 2011 08:12 PM
mouseghb
May 29, 2005 05:04 PM
vdub08
27
Feb 23, 2005 03:42 PM
CW-ITR
Jun 18, 2004 03:57 PM
ZUL8R
Nov 18, 2003 06:14 PM
