1.6 Vtec or Non Vtec???
What kind of differences are you looking for?
For starters, 1.6liter VTEC engines have VTEC, duh.
1.6L VTEC = 127ish hp.
1.6L Non-VTEC = 100ish hp (depending on the model)
It's a sublte change with the SOHC VTEC. If anything, you can just barely hear the engine change tones when it hits.
But the other thing that makes VTEC engines faster is the shorter transmission too. NON-VTEC motors have longer gears, better for fuel economy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch »</TD></TR><TR><TD CLASS="quote">is 150 good for a full 1.6 vtec swap?</TD></TR></TABLE>
yes
yes
if its a d16y8 swap then yes...drop it in and go..
if its a d16z6 swap then you need a few things...
that big red thing up at the top named search will help you out with that tho...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jedi_Sol »</TD></TR><TR><TD CLASS="quote">It's a sublte change with the SOHC VTEC. If anything, you can just barely hear the engine change tones when it hits.
But the other thing that makes VTEC engines faster is the shorter transmission too. NON-VTEC motors have longer gears, better for fuel economy.</TD></TR></TABLE>
How do you explain d15z1 vtec-e and its long gears?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_conference »</TD></TR><TR><TD CLASS="quote">How do you explain d15z1 vtec-e and its long gears?</TD></TR></TABLE>
Well, because the vtec-e is an economy car. It should have longer gears to save more gas. If you have short gears with vtec-e, then what's the point? Hope that clears things up.
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
CX /VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
The higher the number, the shorter the gear = quicker acceleration
But I think I understand where you get confused when I say "cars with VTEC." In a nutshell, people on HT have a mutual agreement that when someone says "VTEC" they are talking about the high-cam-profile-mad-power engines.
Yes, VTEC-E is technically a VTEC engine, but it achieves its variable valve timing and lift fuciton through the electronic manipulation of the valves. Low rpms = 2valves per cylinder. High rmps = 4 valves per cylinder. This generally does not give you the mad power needed to achieve this result:
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
Final Drive---4.250
CX /VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRF1600ej1 »</TD></TR><TR><TD CLASS="quote">1.6 non vtec is from 96+ dx model civics also, the ones with beehive style cats on the exhaust manifold. oh ya throw a header on that y8
forget the head slap a turbo on that motor . You got a good deal
</TD></TR></TABLE>forget the head slap a turbo on that motor . You got a good deal
Does a 97 del sol s w/ the d16y7 have a better gear ratio then a civic w/ same motor? I have the sol and ratio feels quik, redline 2nd @ 60 mph
I bought a clutch for it and tried using one from a 96- civic dx and it didnt fit. The sol had a different flywheel.
Is it possible that the sol has a y8 tranny on a y7 motor from factory?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashoveride »</TD></TR><TR><TD CLASS="quote">
Is it possible that the sol has a y8 tranny on a y7 motor from factory?</TD></TR></TABLE>
Yes, d-series engine/trannys are interchangeable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch »</TD></TR><TR><TD CLASS="quote">im told it has a delsol trans on it but i cant tell... is it better or worse??</TD></TR></TABLE>
It's a little worst because the shifting fork is made of aluminum, so they are prone to breaking.
The y8 shifter forks are made of steel, more durable.
It depends on what del sol tranny it is. If it's a 96+ si transmission, it's the same thing. If it's pre96, it has a z6 tranny, which is pretty much the same but they have an aluminum shift fork versus the steel y8 shift fork.
civickid03
Mar 25, 2004 11:00 AM
16, 96, delsol, difference, distinguish, engines, faster, gears, honda, horsepower, nonvtec, sohc, trans, vtec, y8
gonna have it in this weekend, as long as the rain holds out
