VAFC or SAFC for 98 accord f23????
Old May 11, 2006 | 04:45 PM
leoverte's Avatar
Default VAFC or SAFC for 98 accord f23????
Which is the proper unit to use..the VAFC or the SAFC for a 98 accord f23???
And is either better that just chipping the ecu...which i am not sure can be done since the car is obd2..
Either of the two will be dynoed and tuned by a performance shop just trying to figure out which is better...and i did research, but nothing was specific enough...thanks for you help techs.
Old May 11, 2006 | 06:44 PM
Crono139's Avatar
Default Re: VAFC or SAFC for 98 accord f23???? (leoverte)
The only difference between the two is that with the V-AFC, you can change the VTEC engagement points.
The only option that you have in modifying the stock ECU is sending it out to JET to have them reprogram it.
It all depends on what you plan to do.
Old May 11, 2006 | 06:47 PM
honda3x23's Avatar
or you could get chrome
or you could get an obd1 civic ecu that was chipped and slotted for hondata or uberdata etc etc etc
Old May 11, 2006 | 07:02 PM
Crono139's Avatar
Default Re: (honda3x23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda3x23 &raquo;</TD></TR><TR><TD CLASS="quote">or you could get chrome
or you could get an obd1 civic ecu that was chipped and slotted for hondata or uberdata etc etc etc</TD></TR></TABLE>
It's a bit of a hassle with 6th Gens.
I can only think of a few people that I know of that have switched theirs to OBDI. You will need an OBDI ECU, and an OBDI IACV, which has two wires instead of three that our stock one has.
Also, if you do the swap, you won't be able to pass emissions.
Old May 11, 2006 | 07:48 PM
mattf22b1's Avatar
Im assuming your car is vtec as you mentioned the vafc, i would recommend getting you ecu chipped and then get the vafc as well so that you can tune for other mods and tune you vtec increments. What other mods do you have? oh and dont go obd its way to much of a hassle and as was already stated you wont pass emissions with ease
Old May 11, 2006 | 10:12 PM
honda3x23's Avatar
i always forget about emissions since we dont have it here.
Old May 12, 2006 | 02:58 AM
raceACCORDingly's Avatar
if you have "vtec" on your valve cover get the vafc.
crome or any other rom editer like hondata, neptune, etc.. will require an obd2 to obd1 conversion.
Old May 12, 2006 | 11:13 AM
leoverte's Avatar
Default Re: (raceACCORDingly)
i have the the u-vtec model accord...but i have heard that their is something werid about the 6th gen accords and that the vafc could not function on that model. Soooo...i actually used the safc on my other accord(i also own a 99ex) and now i just want to make sure that i use the correct one, since this accord has a manual trans and more potential than my auto trailer queen....anyhow, i never adjusted the safc on my 99ex since it was just for looks and show...and because what people told me...
My 98 lx has a dc sports 4-2-1 header, full vibrant exhaust system, magnaflow highflo cat, and AEM V2 cold air intake, and also a grounding system. I DEFINTELY plan on turboing this car since i could not turbo the auto, safely without maybe damaging the tranny...so i would like to get the most from the car before the turbo.
My previous daily driver, the eg coupe with a b18b, had a dyno and tuned ecu that worked wonders on the cars potential...so i want to try to do the same for my accord before i turbo it...but i know if i tune the ecu BEFORE the turbo, that would be a problem since i would just have to retune it...so i figured on getting the SAFC or the VAFC which i can always retune, let alone i never knew it was that much of a problem to convert the car to obd1....
Old May 12, 2006 | 11:23 AM
Crono139's Avatar
Default Re: (leoverte)
I also have the ULEV-VTEC motor (F23A4), and my V-AFC II is up, and running perfectly.
As a side note, I don't recommended an AFC for a turbo setup. The AFC hack has its limits, and you'd be much better off with AEM EMS, GReddy E-Manage, or something else along those lines.
Old May 12, 2006 | 02:34 PM
leoverte's Avatar
Default Re: (Crono139)
dam...so if i turbo, i will be wasting money with the vafc II...so can i use the greddy emanage now or just wait till turbo...the aem ems is just out of my range for what i want to spend...not trying to be cheap, but i dont really want to spend that much money,,,??thanks so far crono 139 and everyone else for the help..
Old May 12, 2006 | 05:55 PM
if you are going turbo dont waste your time and money with the vafc.
Old May 12, 2006 | 09:03 PM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 &raquo;</TD></TR><TR><TD CLASS="quote">I also have the ULEV-VTEC motor (F23A4), and my V-AFC II is up, and running perfectly.
As a side note, I don't recommended an AFC for a turbo setup. The AFC hack has its limits, and you'd be much better off with AEM EMS, GReddy E-Manage, or something else along those lines.</TD></TR></TABLE>
for some reason, my friend had problems tuning his turbo'd D16 in his EG hatch with the greddy e-manage and ended up using a SAFC
Old May 12, 2006 | 10:33 PM
leoverte's Avatar
thanks race for the info..
Old May 13, 2006 | 10:33 AM
afc hack is garbage compared to what is available in this day and age. look into an obd coversion harness and a p28 or p72 ecu and crome pro.
Old May 14, 2006 | 12:22 PM
leoverte's Avatar
can i do that before i turbo and it will still work afterwards, or will i need to do retuning...
Old May 14, 2006 | 12:57 PM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leoverte &raquo;</TD></TR><TR><TD CLASS="quote">can i do that before i turbo and it will still work afterwards, or will i need to do retuning...</TD></TR></TABLE>
you will have to retune for the turbo
Old May 14, 2006 | 01:44 PM
leoverte's Avatar
Default Re: (pos_cd5)
yeah thats what i figured....thanks...
gonmaro
Engine Management and Tuning
Mar 20, 2009 12:42 PM
TypeR Chris
May 8, 2004 05:11 AM
Richard.
Nov 23, 2003 12:36 PM
1hotintegra
Jun 29, 2003 03:22 PM
tmekjian
May 4, 2003 08:51 PM
