what should i do with my ecu???
Old Jun 22, 2003 | 11:00 AM
1hotintegra's Avatar
Default what should i do with my ecu???
i have a built head... skunk2 stage1 cams...upgraded valvetrain... stock bottom end..i wana know what i should do about my computer... its a daily driver, 01 gsr, obd2... i was thinkin either get a type-r ecu to raise the redline a lil and get a v-afc and get it tuned...or get an obd1 computer and get hondata.. the only reason im lookin away from the hondata , i would get the s100, is that once i get it tuned i cant change anything liek the v-tec x over like i could iwth the v-afc... and with the v-afc i can see the dispay of all the a/f ratio.. idk tell me what im missing guys
Old Jun 23, 2003 | 04:55 PM
Default Re: what should i do with my ecu??? (1hotintegra)
ttt
Old Jun 23, 2003 | 05:05 PM
genetsang's Avatar
i was going down the same path as you.. i was thinking of using the itr ecu for my setup. but in order for that to happen. you have to get the ecu to relearn your car key. otherwise the immobilzer wont allow you to use the itr ecu for your setup.
Old Jun 23, 2003 | 05:22 PM
Kataku2K3's Avatar
Default Re: what should i do with my ecu??? (genetsang)
I personally would go with the OBD1 jumper and Hondata... It's the easiest most tuneable route if you add more mods later on down the road... As for the VAFC being able to display your A/F, I haven't seen that yet nor would it be very accurate unless you are equipped with a wideband... Hondata gives you the A/F tables aswell as VTEC x-over, ignition timing, etc. Besides that just the fact that you're running an ECU with overall less parameters is nice... If you decide not to go with that then an ITR ECU and VAFC will work fine too... Just my $0.02
Old Jun 29, 2003 | 03:22 PM
Default Re: what should i do with my ecu??? (Kataku2K3)
ttt
ejmatzell
Mar 15, 2006 10:14 PM
RTW DC2R
Dec 15, 2004 01:41 PM
Richard.
Nov 23, 2003 12:36 PM
1hotintegra
Jun 29, 2003 03:24 PM
1hotintegra
Jun 23, 2003 05:01 PM
