how big of shot can put on fully built lsvtec
Exactly 123.5 hp.
You know there is alot more to how much a motor can hold then comp ratio and being "fully built" what ever that even means in this case.
JE pistons and rings, eagle rods, all new bearing, rc 310 injecors, walbor 255 fuel pump, not sleeved, crower stage 2 allmotor race cams and retainers, ect ect if anything else is important then i could elaborate more
if you have stainless steel valves along with the je pistons you could run 150 shot as long as YOU TUNE THE ENGINE TO NOT DETONATE.. you can run alot of nitrous on and engine that is high compression as long as you have the correct spark plugs and a good engine management.. and the correct nitrous system. (direct port) im assuming you are not that experienced in this since you are asking this question. my advice to you is start out small and work your way up. get some experience in running nitrous before jumping to the largest shot.
even though u have a built engine you can detonate easily and melt a piston or valve. do more research and dont try and go all out with out having experience.
shawn
shawn
i wouldnt feel safe with anything over 100hp unless your positive that you can ward off any detonation because at 12:1 with nitrous your on thin ice for detonation. Get a compatable fuel mang system to go along with your direct port setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls95hatch »</TD></TR><TR><TD CLASS="quote">well people were saying direct port, and i dont understand why wet wouldnt be better</TD></TR></TABLE>
WET= NO2 and Fuel DRY= NO2 only
Direct is ports on each intake runner for the cylinders. Single is one shot at the intake before the TB. dont blow anything up now
scUba-stEve
14
Oct 14, 2004 10:17 AM
