will this work?
Old May 11, 2006 | 01:17 PM
civic classics's Avatar
Default will this work?
Im temporarily droping a single VTEC in my car "A 91 SI" will the stock ECU do or will i have to upgrade. And what other ECU can i use for this setup.
Old May 11, 2006 | 01:21 PM
Jesterian's Avatar
24.243.141.75
Default Re: will this work? (civic classics)
A single vtec huh. Did that poor single vtec get seperated from the herd?
pinecone's Avatar
the stock ecu will not work and either will the stock distributor. its not just a drop in, you will need to change some parts out like the o2 sensor and do some wiring.
Old May 11, 2006 | 01:29 PM
the engine is complete the only thingi need is the ECU. any ideas on which can i use. and the other thing is that i dont know if harness work. or can i use a plug and play.
Old May 11, 2006 | 01:35 PM
beatthisspeed69's Avatar
i think all u have to do is wire vtec for the harness..im pretty sure its plug and play
Old May 11, 2006 | 01:46 PM
mntuner2's Avatar
Default Re: (civic classics)
You can use the obd0 system. If you want to run VTEC "Stock-Like" find an imported PW0. Otherwise use a pr4 or pm6 with a msd rpm activated switch. If you use the msd switch you will probably run lean on Vtec change over so chipping the pr4 or pm6 would be a wise investment.
The price of obd1 components are very cheap nowadays, so I see no reason to not convert. That is unless you don't know what your doing then... um... Buy a manual and find someone who is knowledgable about this stuff. Or take a semester of tech school to learn the automotive ropes. Your best ally with these problems is experience. Good luck and GET TO WORK!
Old May 11, 2006 | 02:01 PM
Default Re: (mntuner2)
thank you so much for the schooling
Old May 11, 2006 | 02:51 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic classics &raquo;</TD></TR><TR><TD CLASS="quote">Im temporarily droping a single VTEC in my car "A 91 SI" will the stock ECU do or will i have to upgrade. And what other ECU can i use for this setup.</TD></TR></TABLE>
i suggest converting obd1 and running a p28 ecu..you can always hack up the si dizzy from your car and make it fit the z6 head,,then have the 91 si ecu pm6 chipped with a program called turboedit,,and have some sohc vtec 1.6 maps burned ,,and it will be able to control vtec also as long as you dont want a/c anymore..if you're interested in turboedit with vtec check out http://xenocron.com
Old May 11, 2006 | 03:21 PM
_Keith_'s Avatar
Just convert to obd1 and slap in the proper ecu
alx_90ef
11
Apr 27, 2009 08:07 PM
efKART
Jan 4, 2007 10:28 AM
.M.
Jul 13, 2005 10:54 PM
0554
Oct 13, 2003 11:06 PM
fastgreenmachine
Mar 12, 2003 07:59 PM
