a 95 integra b18 into 92-95
what do i need or need to do to put a b18 in to a 4 door 92-95 dx??
any wiring ?
motor mounts?
does the ecu plug in to the inner hardness of the 92-95
do i need new axles?
any wiring ?
motor mounts?
C'mon dude.
Please search. This is going to be no different then any other 1992-1995 swap on a like-motored car. The amount of doors is irrelevant.
oh man na this info is just for a friend of mine that want to do the swap he doesnt know the about weight diferences so sucks for him
1)Motor
- Tranny
- ECU
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
2) Wiring is plug and play. Depending on which ecu and which b18 you choose, you'll need to wire up a knock sensor/iab's etc.
3) You'd need a b-series rear mount and tranny mount
4)depends on which obd you choose.
5) You'd need b-series axles.
- Tranny
- ECU
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
greeneg1213
16
Jul 16, 2008 01:52 AM
Demon86RJC
11
Jul 15, 2008 11:59 AM
PreludeDude96
17
Feb 3, 2005 04:00 PM
