CHANGED FUEL INJECTORS... STILL THROWING CODE 16 AND LOCKS AT 3500RPM!!!
Old May 11, 2006 | 11:39 AM
axtran's Avatar
Default CHANGED FUEL INJECTORS... STILL THROWING CODE 16 AND LOCKS AT 3500RPM!!!
ok i have no idea what's going on, i changed my injectors (made sure, using obd1 OEM injectors) and i still cannot pass 3500rpm... what is going on?!?!
unplugged VTEC to check, plugged back in, same thing
reset ECU few times, same thing
no other cels but 16
do i need to upgrade any fuel lines? i have the one out the fpr hooked correctly, and the one to the fuel filter hooked correctly... is it too small or something?
Old May 11, 2006 | 11:46 AM
axtran's Avatar
https://honda-tech.com/zerothread/1624039
just refer to this thread
Old May 11, 2006 | 11:47 AM
Jimmy's Avatar
Global Moderator
no need for the second thread..
Old May 11, 2006 | 11:48 AM
dohcVTECeg2's Avatar
Default Re: (axtran)
why did you make a new thread??? just continue in your old one
MUGEN_EG95
Sep 3, 2008 08:57 PM
maxboost_50psi
Feb 11, 2007 08:18 PM
H22A EG6
Mar 31, 2005 07:53 PM
redrocketgsr
Aug 19, 2004 11:13 PM
turboxsi
Sep 17, 2003 06:00 PM
