Restoring OEM Wipers? What process and what paint to go through?
Old May 11, 2006 | 09:37 AM
BolivianFuego's Avatar
Default Restoring OEM Wipers? What process and what paint to go through?
Do any of you guys have any suggestions on what to use on how to sand it down or to get the old paint off? Im thinking aircraft stripper, but also what paint to give it that oem finish back?
Old May 11, 2006 | 09:39 AM
Dforce's Avatar
That's what she said!
Default Re: Restoring OEM Wipers? What process and what paint to go through? (BolivianFuego)
just use sandpaper to sand it down and spray it with whatever black you want, 20 min. job.
Old May 11, 2006 | 09:49 AM
Default Re: Restoring OEM Wipers? What process and what paint to go through? (Dforce)
Does it look like **** after? I remember i did that to a metal intake pipe, and after spraying it with paint it showed the sanding marks still. Which brings me to my next question, what grit sand paper should i use? And what good paint do you guys reccomend to bring it back to that flatish black finish?
Old May 11, 2006 | 09:56 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dforce &raquo;</TD></TR><TR><TD CLASS="quote">just use sandpaper to sand it down and spray it with whatever black you want, 20 min. job.</TD></TR></TABLE>
Old May 11, 2006 | 10:32 AM
Dforce's Avatar
i don't remember the grit of the sandpaper but it's the one that's black and you use it with water. Oh forgot to tell you use metal etching primer.
Old May 11, 2006 | 10:36 AM
ekcivic9's Avatar
is it possible to remove the wiper arm to paint? mines faded silver
Old May 11, 2006 | 10:48 AM
ekcivic9's Avatar
but you wont get the underside painted?
Old May 11, 2006 | 10:57 AM
Default Re: (Dforce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dforce &raquo;</TD></TR><TR><TD CLASS="quote">i don't remember the grit of the sandpaper but it's the one that's black and you use it with water. Oh forgot to tell you use metal etching primer. </TD></TR></TABLE>
This gives it that oem finish? U got pics? And Pics of the Paint can or maybe a link?
Old May 11, 2006 | 10:58 AM
Vincent.'s Avatar
Default Re: (BolivianFuego)
Powdercoat them...
Old May 11, 2006 | 11:33 AM
bryant's Avatar
Default Re: (Vincent.)
Just buy new ones from honda. They are like $12. By time you spend all that money on cans of paint and sand paper you could have had OEM that is going to last ten times longer. The paint usually fades 6 months, to a year later with that spray paint crap. OEM last a good 5 years AT LEAST before they start to fade, more like 10 if taken care of.
Old May 11, 2006 | 11:45 AM
lamsv's Avatar
Default Re: (bryant)
powdercoat
Old May 11, 2006 | 12:06 PM
dohcVTECeg2's Avatar
Default Re: (lamsv)
i got mine from the dealer. they look far better then painted ones
Old May 11, 2006 | 04:16 PM
ekcivic9's Avatar
Default Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">i got mine from the dealer. they look far better then painted ones </TD></TR></TABLE>
how much did they cost you?
Old May 11, 2006 | 04:33 PM
Default Re: (lamsv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryant &raquo;</TD></TR><TR><TD CLASS="quote">Just buy new ones from honda. They are like $12. By time you spend all that money on cans of paint and sand paper you could have had OEM that is going to last ten times longer. The paint usually fades 6 months, to a year later with that spray paint crap. OEM last a good 5 years AT LEAST before they start to fade, more like 10 if taken care of.</TD></TR></TABLE>
Checked it up, its like 30 each....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lamsv &raquo;</TD></TR><TR><TD CLASS="quote">powdercoat</TD></TR></TABLE>
Wouldnt that be expensive?
iheartmyh0nda
Paint and Body
12
Jun 14, 2007 09:03 PM
baozer
11
Oct 18, 2006 01:22 PM
SOLO1racer
Jan 16, 2005 07:15 PM
RacerSi
Dec 30, 2003 05:22 PM
The Alchemist...
Aug 7, 2003 03:27 PM
