b16a2 mounts question
Old May 10, 2006 | 09:39 PM
pinoyboy204's Avatar
Default b16a2 mounts on EK....have some questions!
The b16a2 swap is being done on a 96 civic cx. I've already purchased a rear transmission bracket off a 99-00 Si/SiR. and have the drivers side mount bracket. the only thing left I think I need to order is the front transmission bracket and i'll reuse my upper tranny mount and reuse civic mounts. is there anything else i need? btw, my car does not have a/c so do i still need to purchase a A/C bracket pictured here...
please let me know guys!!
Modified by pinoyboy204 at 6:51 AM 5/11/2006
Old May 10, 2006 | 10:27 PM
SuperSlow's Avatar
Default Re: b16a2 mounts on EK....have some questions! (pinoyboy204)
no
Old May 10, 2006 | 11:51 PM
Stripped Honda's Avatar
99-0104
Default Re: b16a2 mounts on EK....have some questions! (SuperSlow)
no there is no need to get the other bracket ... because your ac compressor will not be installed ... other wise it bolts up as normal
Old May 11, 2006 | 12:06 AM
hatchi's Avatar
you will need to get a b series a/c bracket either gsr p72 or si p30 one.
i have front tranny bracket for sale make offer
Old May 11, 2006 | 04:19 AM
Default Re: b16a2 mounts on EK....have some questions! (hatchi)
so can anyone confirm that I don't need the 99-00 Si/SiR a/c bracket???
Old May 11, 2006 | 08:13 AM
bump!
Old May 11, 2006 | 09:30 AM
sicones's Avatar
you do need that bracket, obviously there is a torque/engine mount attached to it
Old May 11, 2006 | 09:44 AM
rmcdaniels's Avatar
Default Re: b16a2 mounts on EK....have some questions! (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">you do need that bracket, obviously there is a torque/engine mount attached to it </TD></TR></TABLE>
^^^^^^^^^^^ I agree ^^^^^^^^^^^^^^^
(and I had a B16A2 in the car for a while)
Old May 11, 2006 | 09:48 AM
civichbcx's Avatar
Yes! you need the A/C bracket because it is not just a bracket....it is a Motor mount too. Otherwise the only mount that will be supporting/holding up the driver side of the motor would be that upper mount by the timing belt. Put it on!
Old May 11, 2006 | 09:58 AM
emotionisdead's Avatar
Very Emergency!!
just use the 99-00 si one and remove the pulley and the bolt tensior right by it. the a/c mount is also the driver's side torque mount, i woul definitley run one.
Old May 11, 2006 | 10:36 AM
TylerH's Avatar
Default Re: b16a2 mounts on EK....have some questions! (emotionisdead)
Yes you need it. They wouldn't make it for no apparent reason.
Old May 13, 2006 | 11:17 AM
Default Re: b16a2 mounts on EK....have some questions! (TylerH)
Will a 94 integra ls front torque bracket work?? as I can get one locally.
Modified by pinoyboy204 at 6:26 AM 5/14/2006
Old May 13, 2006 | 05:56 PM
TTT...
Daniel99
Jul 12, 2018 09:17 PM
EG6KILIN
May 24, 2010 08:07 AM
Youlose1305
May 18, 2006 06:36 PM
ekb16
Oct 22, 2005 02:28 AM
CNSK
Aug 5, 2004 12:36 PM
