b16a2 mounts question
b16a2 mounts on EK....have some questions!
The b16a2 swap is being done on a 96 civic cx. I've already purchased a rear transmission bracket off a 99-00 Si/SiR. and have the drivers side mount bracket. the only thing left I think I need to order is the front transmission bracket and i'll reuse my upper tranny mount and reuse civic mounts. is there anything else i need? btw, my car does not have a/c so do i still need to purchase a A/C bracket pictured here...
please let me know guys!!
Modified by pinoyboy204 at 6:51 AM 5/11/2006
Re: b16a2 mounts on EK....have some questions! (SuperSlow)
no there is no need to get the other bracket ... because your ac compressor will not be installed ... other wise it bolts up as normal
Re: b16a2 mounts on EK....have some questions! (hatchi)
so can anyone confirm that I don't need the 99-00 Si/SiR a/c bracket???
Re: b16a2 mounts on EK....have some questions! (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">you do need that bracket, obviously there is a torque/engine mount attached to it </TD></TR></TABLE>
^^^^^^^^^^^ I agree ^^^^^^^^^^^^^^^
(and I had a B16A2 in the car for a while)
Re: b16a2 mounts on EK....have some questions! (pinoyboy204)
Yes! you need the A/C bracket because it is not just a bracket....it is a Motor mount too. Otherwise the only mount that will be supporting/holding up the driver side of the motor would be that upper mount by the timing belt. Put it on!
Very Emergency!!
just use the 99-00 si one and remove the pulley and the bolt tensior right by it. the a/c mount is also the driver's side torque mount, i woul definitley run one.
Re: b16a2 mounts on EK....have some questions! (TylerH)
Will a 94 integra ls front torque bracket work?? as I can get one locally.
Modified by pinoyboy204 at 6:26 AM 5/14/2006
Daniel99
07-12-2018 09:17 PM
