What's missing from this distributor?? Pic Inside...
Old May 10, 2006 | 03:27 PM
B18C_EJ8's Avatar
Default What's missing from this distributor?? Pic Inside...
Alright... I am in the process of pulling the MSD ignition from my car, as it is causing problems...
Pulled the cap and rotor and discovered this huge gaping hole where something obviously is missing. So it looks like from acuraautomotiveparts.org that I'm missing the stock coil, but I can't really see what else?
It looks like I've still got the ignitor; I think that's the thing that the wires attach to, but I really have no idea...
Any thoughts???
Old May 10, 2006 | 04:00 PM
BMaDOHC's Avatar
Default Re: What's missing from this distributor?? Pic Inside... (B18C_EJ8)
just a coil goes there, msd was using an external correct?
Old May 10, 2006 | 04:03 PM
B18C_EJ8's Avatar
Yes, was using an external blaster coil...
So in theory, I should be able to pick up a coil, and wire it back in, and she should start right up??
Should I buy a genuine OEM coil or will an Advance Autoparts-type coil be sufficient??
Old May 10, 2006 | 06:25 PM
B18C_EJ8's Avatar
Any other ideas from the night crowd?
Old May 11, 2006 | 03:12 AM
B18C_EJ8's Avatar
Hmm... How about the morning crew?
Old May 11, 2006 | 03:18 AM
Mikey3000's Avatar
Default Re: (B18C_EJ8)
couldn't you just use your msd blaster coil? thats what i'm doing, w/no MSD.
Old May 11, 2006 | 04:12 AM
B18C_EJ8's Avatar
Dunno. That's why I'm asking questions...
But I'm thinking that there may be a problem with the MSD coil, so I want to put everything back to stock to try to eliminate my spark cut problems...
Old May 11, 2006 | 04:17 AM
EE_Chris's Avatar
I'd stick to OEM for ignition components.
Old May 11, 2006 | 04:48 AM
boostedSI90hatch's Avatar
Banned
Default Re: (EE_Chris)
there looks to be no rotor either...
Old May 11, 2006 | 07:02 AM
BMaDOHC's Avatar
Default Re: (boostedSI90hatch)
use oem please, aftermarket is nothing but problems with electrical. ya you should be able to slap a coil in, wire back in the three wires and be all set, and put rotor back in
Old May 11, 2006 | 07:19 AM
devnull's Avatar
It has been well documented that the OEM coil sucks. That being said it is also know that the aftermarket ignition control boxes will cause problems if not setup correctly. I had a Crane ignition box on mine (CD, MS) and it worked great for 2 years, never had one problem. If you have an aftermarket coil just wire it up and make sure you have a good cap. I would recommend an MSD external cap and the coil connection is molded to the cap thereby removing chances of damage due to vibration.
CD = Capacitive Discharge
MS = Multi-spark
Old May 11, 2006 | 02:10 PM
APEX CRX's Avatar
Default Re: (devnull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devnull &raquo;</TD></TR><TR><TD CLASS="quote">It has been well documented that the OEM coil sucks. That being said it is also know that the aftermarket ignition control boxes will cause problems if not setup correctly. I had a Crane ignition box on mine (CD, MS) and it worked great for 2 years, never had one problem. If you have an aftermarket coil just wire it up and make sure you have a good cap. I would recommend an MSD external cap and the coil connection is molded to the cap thereby removing chances of damage due to vibration.
MS = Multi-spark</TD></TR></TABLE>
agreed. I have a MSD box, blaster coil and cap on my B18C1 CRX and its never given me a problem (5 years running)
Old May 11, 2006 | 05:06 PM
B18C_EJ8's Avatar
Just ordered a new OEM coil. Wish me luck that there's nothing else missing...
kelvinchau25
Aug 29, 2006 07:05 PM
93solcontender
Mar 9, 2003 02:33 AM
ernald711
Mar 4, 2003 07:26 AM
crx(gator)
Dec 4, 2001 09:09 AM
