dam i have a problem..obd related
i bought a obd2 head. long story..lol. But anyways here is my problem and how do i fix it?
i have a obd1 car(94 hatch)
i have an obd1 dizzy
i have an obd1 ecu(p28)
i have an obd1 block(b20) no crank angle sensor
i want to use my obd1 civic wiring harness(dx)
but my head is gsr obd2.
Also can i make the obd2 injectors fit into my civic harness(obd1)
how can i make this work?
and also can i just get rid of the stock IM and if i can what do i do with that sensor?
it doesnt matter if the head is obd-2 or 1. the easiest way to go about is just get some obd-1 injectors. looks like you are going b20vtec so i would just get some 310 injectors anyways. you can use the dx harness but you are gonna have to wire the vtec in. and for the harness you are also gonna need to extend some of the plugs
thanks i already have the vtec wiring done thanks to rywire. so i just get some injectors and ill be good to go?
Contender25
Aug 16, 2007 07:14 PM
