97 jrsc'd gsr misfire problem. need help
Old May 10, 2006 | 09:31 AM
AllMotorRP's Avatar
Default 97 jrsc'd gsr misfire problem. need help
ok so my car started misfiring about a month ago. i changed the plugs, wires, and then got a new distributor. the car still misfires and now its alot slower and sluggish with the dist.
im going to do a compression check today and hope that goes over good.
any of you guys have this problem.
setup is just basic boltons with jrsc on 6lbs....
i dont get it
Old May 10, 2006 | 11:34 AM
AllMotorRP's Avatar
noone can help???
Old May 10, 2006 | 11:42 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (AllMotorRP)
No idea but, any kind of Tune on it ?
Old May 10, 2006 | 02:06 PM
AllMotorRP's Avatar
no thats one of the things i had needed , never did though....
Old May 10, 2006 | 02:15 PM
Hype-R Stalker
I can't tell you much since it's forced induction, and I don't really have much experience in that area,
You might even want to try the FI section here if you haven't yet.
Is there any changes in your timing?
Old May 10, 2006 | 02:49 PM
Orangecivic251's Avatar
Default Re: (FlatBlackTeg)
yeah patterson i heard you where having trouble check your timing. and i don't say get it tuned cause hell you said it ran fine till now. you met my boy ryan in atlanta had 00 gsr he had the same problem till i put on hondata in there for him. i had checked the timing put 2 distributors in and everything finally it works great now.
on second note when you installed the distributor did you center it in the middle or what?
Old May 10, 2006 | 04:56 PM
AllMotorRP's Avatar
yeah timing is fine checked when put the dist. in....
yeah Ryan is a good guy , his car looks badass too. hondata might help but im gonna make sure nothing bad happened first.
Old May 10, 2006 | 06:42 PM
Dartanian's Avatar
Default Re: 97 jrsc'd gsr misfire problem. need help (AllMotorRP)
What does your spark plug gap look like? Is it throwing codes...or just bogging under boost?
Old May 10, 2006 | 09:38 PM
AllMotorRP's Avatar
plugs are gapped at 28. they look pretty good. it boosts fine just you can tell its slower and at a rest it idles rough. throwing misfire code.
Old May 10, 2006 | 10:00 PM
Sack Master's Avatar
Maybe you have an injector sticking or it went out. Just something else to look at.
Old May 11, 2006 | 06:10 AM
dirtyrican987's Avatar
Default Re: (Sack Master)
my friends stock gsr was misfiring it was a scortched valve
Old May 11, 2006 | 09:29 AM
AllMotorRP's Avatar
yeah thats what ive heard.
thanks for the help
Old May 11, 2006 | 09:44 AM
TheNosR's Avatar
does it misfire at idle and just driving normal or does it misfire only when boosting? since you lost power you might not be running on all cylinders my be valves are bad maybe you screw up your spark plugs agian their are many things that make a car miss
Old May 11, 2006 | 09:46 AM
Vitesse's Avatar
Default Re: 97 jrsc'd gsr misfire problem. need help (TheNosR)
when was the last time you ran some injector cleaner ?
Old May 11, 2006 | 02:46 PM
AllMotorRP's Avatar
scanner says missfire on all 4 cy's. ran injector cleaner less than a week ago. car you can tell has lost power but really just tell with the idle problem at a stop. just doesnt pull hard but no bogging either.
Old May 11, 2006 | 03:35 PM
wow all four cylinders hmmm if your in town bills wholesale has a nifty compression tester in case and all for like $20 maybe you should give that shot if you hadn't already
Old May 11, 2006 | 04:42 PM
AllMotorRP's Avatar
yeah i have one at home, start there i guess.
Old May 12, 2006 | 05:00 AM
Vitesse's Avatar
Clean the PCV.
Old May 14, 2006 | 01:15 PM
XxNampsterxX's Avatar
I had the same problem with my JRSC Integra. I ended up burning a ring. I was also running 6 lbs with basic bolt-ons. I had to change my block. I did the same thing as you by changing every part I could think of and nothing helped. I ended up doing a leak down test and was losing a lot of compression. Hopefully, your problem isn't as severe as mine was. Good luck.
Old May 21, 2006 | 09:20 PM
AllMotorRP's Avatar
well to update everyone did a compression test and it went 185, 100, 50, 150 accross.
looks like im in the market for a new motor , not a big fan of rebuilding.
ef_hopeful
Jan 28, 2008 07:10 PM
I CRX I
Sep 27, 2007 07:51 AM
xtrmstr69
10
Nov 9, 2005 07:26 PM
mugen97ek
Jul 22, 2005 08:30 PM
wtc7676
Apr 2, 2004 12:16 PM
