Brake identification urgent help needed!
Old May 10, 2006 | 07:42 AM
blumpfish's Avatar
Default Brake identification urgent help needed!
I was going to change my brake pads yesterday, so i go and get brake pads, they don't fit.. i depress the caliper all the way put them on , and they dont clear the rotor.. they're too thick and the clip on it is *** backwards from the ones that were on there.. as far as i know they are stock 88 crx si front brakes. the guy i bought it from didnt say otherwise, but the pads for those brakes arent fitting .
any way it can be identified maybe by the code on the calipers? how can I identify what brakes these are?
Old May 10, 2006 | 08:42 AM
crx_88_si's Avatar
where did u get the pads?
I got some from a autozone type place (canadian tire in Canada) and the box was correct for 90-91 CRX Si Rear Pads but the pads in it were completely wrong.
Go back to the store and compare between other boxes.
Old May 10, 2006 | 08:44 AM
blumpfish's Avatar
Default Re: (crx_88_si)
I got them from autozone, im going to go back there today and hope thats whats going on. Thanks
Old May 10, 2006 | 10:54 AM
blumpfish's Avatar
Default Re: (blumpfish)
nope, it was the rigth pads, i said expletive it and got new rotors too, gonna try this again.
Old May 10, 2006 | 11:35 AM
blumpfish's Avatar
Ok, the old paper thin brake pads barely came off, with the new rotors that are the right size, same as the old ones, and brake pads that are for my year crx.. they do not fit over the rotor.. it is not the other brake pad that is keeping it from going over its the caliper , the caliper itsself is just not wide enough for new pads to fit over.. this is pissing me off.. so bad.. no one can identify calipers??
Old May 10, 2006 | 01:08 PM
blumpfish's Avatar
well, thanks for all the help everyone!! /end sarcasm
Old May 10, 2006 | 01:25 PM
Tyson's Avatar
take off the backing plate. you dont need it. thats the extra thickness that is preventing you from putting the brakes on.
Old May 10, 2006 | 01:36 PM
UltimX's Avatar
Default Re: (Tyson)
maybe u have da brakes? I know people upgrade them if they do a swap and get them with there disc brakes.
Old May 10, 2006 | 01:38 PM
Tyson's Avatar
Default Re: (UltimX)
i can visually confirm those are 88 Si brakes. which are the same as all 88-91 DX brakes anyway.
show me a pic of the brake pads and ill be completely certain.
Old May 10, 2006 | 03:05 PM
blumpfish's Avatar
Default Re: (Tyson)
this is not making any sense, ill try to take off the back plates.. its gonna be a really tight fit if it does fit
here are some pics of the pads
thanks!
Old May 10, 2006 | 03:08 PM
Tyson's Avatar
you got the right pads. just take off the backing plates.
KevinEF7
Suspension & Brakes
24
Jun 30, 2014 09:35 AM
racinmason85
Suspension & Brakes
Feb 20, 2011 04:37 AM
jlowellintegra
Dec 23, 2010 09:46 PM
jester
15
Oct 5, 2003 06:29 AM
yaya
May 19, 2003 08:18 PM
