B18C ARP head stub torque specs?
the head studs have been used twice before so they may be stretched a little
but anyways, what are the torque specs for the GSR motor? i believe it is around 71ft/lbs but I am not sure
and what size is the 12-point nut at the end?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C »</TD></TR><TR><TD CLASS="quote">I torqued mine down to 70 with the ARP lube.</TD></TR></TABLE>
what difference does the lube make? and what is its purpose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec »</TD></TR><TR><TD CLASS="quote">what difference does the lube make? and what is its purpose</TD></TR></TABLE>
The lube gives you an accurate torque reading. If ARP says to torque something xxft/lbs using their lube, use their lube. Some people say that all it is, is Moly.. but ARP says otherwise.
I lube everything I torque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec »</TD></TR><TR><TD CLASS="quote">i wish i had some
I have some redline racing assembly lubericant, do you think that will work properly?</TD></TR></TABLE>
That is for bearings, cams, etc..
Stop by some local performance shops, most of the time shops have shitloads of the stuff.
