aftermarket power door lock?
With most alarms, you'll need a relay and 2 actuators. DEI sells a relay for door locks, i think its the 451m, but not 100% sure on the model number. That relay will plug into the alarm brain, and needs power and ground, then wire both acutators to it. Then mount the actuators on the doors behind the door panel, and connect it to the door lock rod. Put your doors back together and you're done.
importdude2000
Audio / Security / Video
12
Jun 20, 2011 06:54 PM
alacard
Jun 7, 2008 03:32 PM
