How to get off...
Old Apr 10, 2002 | 04:56 PM
EFing8's Avatar
Default How to get off...
the crank pully nut. is it reverse thread? also the flywheel. Any little tips?
Old Apr 10, 2002 | 04:59 PM
RR98DX's Avatar
Default Re: How to get off... (CND_CRX)
big *** impact gun, or ALLOT of force with a breaker bar.
Old Apr 10, 2002 | 07:22 PM
rainforest's Avatar
Default Re: How to get off... (95CivicSi)
breaker bar then a gear puller to take the crankshaft pully off.
Old Apr 10, 2002 | 08:01 PM
Kataku2K3's Avatar
Default Re: How to get off... (rainforest)
I took a lil piece of aluminum and drilled two holes in it. From the little access door on the backside of the flywheel you can look the crank. Then just have a good breaker bar and the **** should come right off. Also it is threaded normal and so are all the flywheel bolts.
[Modified by JDMspecEG6, 5:01 AM 4/11/2002]
jasonfierst
Oct 18, 2009 01:04 PM
ecstacyofgold
Apr 11, 2009 09:13 PM
shauniewalnuts
19
Dec 25, 2004 11:33 AM
Bspec18
Nov 15, 2003 01:11 AM
Dr Pooface
Jan 31, 2002 06:07 AM
