God Damnit
Old May 9, 2006 | 03:05 PM
Mavrick's Avatar
Default God Damnit
Hey all, I have this recurring problem with my honda and it is angering me severely. Every once in a while I will go to start my car and it will not start. Nothing happens, just a click. So ive started replacing parts. Sometimes it starts sometimes it rolls really slowly, or it just clicks and nothing happens. I have to keep trying the key until it finally does start, now the problem is that when it does start, it starts as if the battery was brand new. I have replaced the starter, the ignition switch, both battery cables, and cleaned up the grounds. The only thing I havent changed is the battery as I have never heard of a battery sometimes working. I took the battery in to get tested and one shop says its fine and the other says it needs replacing. Has anyone else ever had a battery that worked sometimes but not all the time? I also noticed the battery hold down has been removed so its just the cables fastening it to the car. HELP IS NEEDED
Old May 9, 2006 | 03:09 PM
boosted civic 2k6's Avatar
Default Re: God Damnit (Mavrick)
nope. never heard of that. but if u let it drain over night or havnt charged it in a while it could be dead.
Old May 9, 2006 | 03:10 PM
lonefuzzy79's Avatar
Why do people assume the worst and just start throwing parts at a problem. If it was an old battery I would have just replaced it, OR you could have thrown a jump on it and see if that fixed it. Get a new battery. Start small and go from there.
Old May 9, 2006 | 03:38 PM
TurboCoop's Avatar
Default Re: God Damnit (lonefuzzy79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lonefuzzy79 &raquo;</TD></TR><TR><TD CLASS="quote">Why do people assume the worst and just start throwing parts at a problem. If it was an old battery I would have just replaced it, OR you could have thrown a jump on it and see if that fixed it. Get a new battery. Start small and go from there.</TD></TR></TABLE>
yup
Old May 9, 2006 | 03:40 PM
Mavrick's Avatar
Default Re: God Damnit (TurboCoop)
good plan, I just unplugged alternator and it does the exact same thing.
Old May 9, 2006 | 03:44 PM
dangle's Avatar
Word of advice for the future;
Complaint, cause, and correction. You've probably just wasted a gripload of money on parts that were fine. If it ain't broke, don't fix it.
Smells like a battery and some bad connections to me. Good luck.
Old May 9, 2006 | 03:47 PM
Syndacate's Avatar
does it start fine if u jump it?
Old May 9, 2006 | 04:37 PM
Mavrick's Avatar
Default Re: (Syndacate)
no, it does the exact same thing. Im thinking faulty battery for sure.
Old May 9, 2006 | 04:40 PM
y2kferari's Avatar
Default Re: (Mavrick)
battery, then check battery fuses. only thing left, lol
Old May 9, 2006 | 04:45 PM
ezza's Avatar
Default Re: (y2kferari)
same thing happened to me, turns out the battery had weird terminals and just needed tightening down good good luck
Old May 9, 2006 | 07:11 PM
Syndacate's Avatar
ya, def. change that battery first of all...seems that u checked out the stuff u shoulda checked out second, first....change out that battery
Old May 9, 2006 | 07:26 PM
Jdmon079's Avatar
lol
Old May 9, 2006 | 07:48 PM
stockbee's Avatar
how about using something less offensive as a subject title......
even so good luck with whatever it is you're facing.
specbb6
Honda Civic (2006 - 2015)
Jun 24, 2012 03:07 PM
love_my_ekcoupe
Jan 26, 2010 08:20 PM
rawsx
Mar 10, 2008 10:41 AM
speedracer33
May 2, 2005 08:57 AM
LaOstha
17
Feb 21, 2005 02:15 PM
