Need some advice on brakes
my front driver side breaks keep squeeking everytime i step on the break, they're new sports breaks and break pads are fine. My friend said it might be from the the break clip or the there to close together and its scratching. Any suggestions? How much would it cost to fix?
any place should be willing to fix them or replace the for 60-100 bucks i work for good year we would charge you like 75 bucks to put new pads on there and turn your rotors
I would recommend posting pics cuz your description isnt makin much sense... If your brakes are squeeling then its usually from either, brake pads are worn down to the metal, rotors are worn down or have a large lip on the edge, and possibly you got grease-oil-dirt on the rotors.
check out that stuff and see, cheapest way would be to clean off the rotors with some brake parts cleaner...
