Kill Switch in an EG w/ a Turbo Timer
What is needed to put a kill swith in a turbo timed car? obviously the car needs to stay running after i leave it.. so how would a kill switch come to play in this situation?
i was thinking just a starter kill, both a switch and a 'push-hold' button...? how would i go about wiring this up, would i need a relay or could i just throw a switch in the middle of the starter wire? (black/yellow i think it is?)
any help would be appreciated, im just trying to get it done now while my dash and interior is out. Thanks in advance
Modified by HatchEh2 at 11:40 AM 5/10/2006
i know theres gotta be turbo timed guys on here with kill switchs? please, help a brother out living in high risk jersey!!??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTteg »</TD></TR><TR><TD CLASS="quote">Find a way to interrupt your starter wires with a switch or two.</TD></TR></TABLE>
yea i know that, i just dont wanna go snipin wires w/o hearing from someone that did it before. And im wondering, will i need a relay like with fuel cut offs??
cmon theres gotta be SOMEBODY with a killswitch in there turbo timed car?!?!?!?!
this is holding up me putting my car back together, id rather do it while it just sits as a shell with no motor or interior...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc »</TD></TR><TR><TD CLASS="quote">PM'ed with a slightly different way...if you are in a high risk area.
sent you a PM
</TD></TR></TABLE>sent you a PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">
sent you a PM</TD></TR></TABLE>
replied
replied
good ****, but im just lookin to throw a quick, effective kill switch while my cars apart, i didnt wanna just put a switch right smack dab in a circuit w/o relays and such required...
again...ANYONE turbo timed with a kill?? or should i try another form?
It can be rigged up with a relay, I had it set up with my old alarm, but got lazy when installing the new one, pm me if you have any questions.
I did it, Press a button once then start the car, car will run after it is turned off, but won't start till the button is pressed. I do a diagram when I have time.
why not just put a switch in line with the starter "start" signal wire from the ECU? there can't be very much voltage going thru that line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">why not just put a switch in line with the starter "start" signal wire from the ECU? there can't be very much voltage going thru that line.</TD></TR></TABLE>
push start baby...
push start baby...
isnt the start switch only on autos?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JK_Motorsports »</TD></TR><TR><TD CLASS="quote">I did it, Press a button once then start the car, car will run after it is turned off, but won't start till the button is pressed. I do a diagram when I have time.</TD></TR></TABLE>
Did you ever get around to making that diagram?
usually the kill switch is wired into the ebrake with a turbo timer....So when you do leave ur turbo timer on...and if sumone just happens to hop in and let the ebrake down...it will shut the car off immediatley....
http://www.sonolithics.com/files/bosch.pdf
this pdf shows how you can make stock switches like ebrake, cig lighter, headlight switch, etc... starter/fuel kill switches with a relay
ive thought about a fuel cutoff w/ a turbotimer but its way over my head, starter is alot easier.
imzjustplayin
Apr 17, 2008 09:08 AM
HatchEh2
15
May 18, 2006 09:26 AM
intekragsr
Jun 11, 2003 08:41 PM
lazyvietboi
Nov 6, 2001 08:58 AM
