Never seen this happen..
Old May 9, 2006 | 11:38 AM
ZCcivicBOI's Avatar
Default Never seen this happen..
i have a 93 dx 5spd accord f22a1 previous owner put a adjustable cam gear on it he had it running then he put water in the radiator the head stoped and the timing slipped some teeth so we put the belt back on tdc and the head put it back together and it ran like crp so i expected bent valve well i baught it and took it home did compression chech and all were good so that means no bent valve well i tried to start it again and it ran but like crap then couple seconds later BAM! the cam snaped and the cam gear broke off camshaft broke too i was like wtf? anyone know what could make this happen?
Old May 9, 2006 | 01:11 PM
Chiovnidca's Avatar
Default Re: Never seen this happen.. (VtecE_rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecE_rex &raquo;</TD></TR><TR><TD CLASS="quote"> the cam snaped and the cam gear broke off camshaft broke too i was like wtf? anyone know what could make this happen? </TD></TR></TABLE>
Lack of oil can do it.
Old May 9, 2006 | 02:53 PM
knucklehead11's Avatar
My mind ran out of breath reading that huge *** run on sentence.
Punctuation would help.
Old May 9, 2006 | 11:55 PM
BlUAc's Avatar
Default Re: (knucklehead11)
that could have happened due to it being to tight i've heard of that before but that would have not made it run like crap unless he didnt set the timing ryt
Old May 10, 2006 | 12:09 AM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knucklehead11 &raquo;</TD></TR><TR><TD CLASS="quote">My mind ran out of breath reading that huge *** run on sentence.
Punctuation would help.</TD></TR></TABLE>
shoot...here we go again english 101.........man who gives a crap about his writing skills .,,, wow you chose a name that really fits you...
Yo vtec,, what do you mean by the head stopped ?? why did you put water in radiator ,, did car overheat at all that you know of ??
Old May 10, 2006 | 12:35 AM
YeuEmMaiMai's Avatar
Default Re: (accord-pro)
anh discoloration on the cam or journals in the head?
What is the condition of the oil? (you might want to get an SOS analsys completed)
Is the water pump functional?
Did you just buy this car? Sounds like it has had a long hard life.........
Old May 10, 2006 | 06:59 AM
poundedhatchcrap's Avatar
Default Re: (YeuEmMaiMai)
The cam broke off at the gear. It was running fine both times, but when water goes in either the rad, or when thermostat opens the car shuts off violently. Loud crack noise the first time it happend. Then the cam broke off at the gear the second time
Old May 10, 2006 | 08:29 AM
lunarone's Avatar
i agree punctuation would really help you find the solution to your problem faster with no punctuation people are like what am i reading and then they get lost and try to think about what is going on and they ask themselves if they really want to answer your question at all because they cant even read the **** straight so they dont bother reading the rest of it and they just let you know to use more punctuation because its so friggin hard to read without it
Old May 10, 2006 | 09:14 AM
ZCcivicBOI's Avatar
Default Re: (lunarone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunarone &raquo;</TD></TR><TR><TD CLASS="quote">i agree punctuation would really help you find the solution to your problem faster with no punctuation people are like what am i reading and then they get lost and try to think about what is going on and they ask themselves if they really want to answer your question at all because they cant even read the **** straight so they dont bother reading the rest of it and they just let you know to use more punctuation because its so friggin hard to read without it</TD></TR></TABLE>
lol take some of your own advice bro.. not one period in that haha
Old May 10, 2006 | 09:41 AM
urbanlegend21's Avatar
New User
Default Re: (VtecE_rex)
Sounds like your water pump froze up
da itr-t
Feb 14, 2009 12:29 PM
kornerk12
Dec 5, 2008 11:48 AM
Po0r LiTTle CoUpe
Aug 3, 2006 08:16 PM
adaml2nv
Dec 1, 2004 07:41 PM
pwrofdrm
Jul 24, 2004 09:23 PM
